Anyone have to combat rust? I live 3 blocks from the ocean so there's quick and aggressive decay of cars here. Trying to come up with an idea of "rust proofing" my truck when I get around to repainting it.
On the frame & suspension parts you can use POR-15,this product can be applied directly over rust, & will stop it & seal it! Use also on the whole interior metal than over with a sound deader,I use Fat Mat. Use also in the wheel wells,than spray a rubberized under coat . On the exterior, you should remove all the surface rust ,& I'd spray a epoxy primer over all, than your finish paint! This should protect pretty well against rust!
