Looking for a relatively cheap 20r or 22r. If its running awesome, if not its ok as I will just rebuild it. Would prefer to get one that needs little to no machine shop work. Dont necessarily need a intake/carb or exhaust. I have a rebuilt carb, will custom make a header, and can get a intake mani for cheap. Would entertain the idea of a 75-78 parts truck as I can use the tranny, disc brakes and rear axle all to swap onto my 67 stout. Willing to drive a bit. Let me know.
i have most of the parts to make a 22r, and am located just outside of portland, but can not deliver... sorry. but if you want anything hit me up. the crank is bad and the block needs bored, one of the pistons is bad, but everything else is pretty good shape. even have a good head.
Try this, but may be too far of a drive. Resale the tranny to get some of your funds back. If not, be patient, its only a matter of time be fore one shows up.
Im down in the tri cities and I have everything you're after. Good core 22r, W50 trans etc. I have a couple engines to choose from that could be runners with a bit of work and a pair of W50's one is known good the other is assumed good. I have all related parts that are specific to the.swap too.
Good lord man martinez is only about a thousand miles away... I've got a good running 20r that I'd let go before I'd let him drive that far have a heart man!
Well got a killer deal on a 20r complete from filter to oil pan running and driving with 5 spd 2wd trans for 150. (includes brand new starter worth about 75 bucks) Guy also sold me the whole front suspension/cross member/ etc and some lowering blocks for 60 more bucks. So for 210 I got engine (running driving with new starter), 5 speed trans (with good condition original leather shift knob! woot!) A set of springs to use to cut and put in the front of my stout, and a complete front disc brake setup to put up front as well! and rear lowering blocks... Score!
