Oregon 90 Toyota pickup rice eater
Discussion in 'Introduce Yourself' started by ffryno13247, Jan 4, 2012.
  1. ffryno13247
    ffryno13247 Member
    New to the site, been lurking around on here for awhile. Any way I have 90 standard cab short bed, 5spd with a 22re for right now. It used to be a "Prerunner" I use that loosely cuz the guy who had it had 5" of body lift and a some stock lower a arms with 6" peice spliced in the middle(very very frustrating) any way it's all gone and oem frontend in it's place with some extra goodies. And the body lift is all Out and new body bolts in there place
    I put v6 torsion bars on it and sway bars just rebuilt my 22re (7mgte being built right now) and it has baja bedsides on it. I'll start a build thread here when I get more done
    Ps anyone know how to post pics from an iPhone?
  2. Byronics
    Byronics Veteran
    Hilo, Hawaii
    89' Single cab
    Set up an account on photobucket n' there are mobile settings...
    Photobucket Help - Change Your Mobile Settings
    you can upload pics via MMS n photobucket creates an image code for every pic you upload. then you can copy n' paste the image code to ur posts on TM... :waytogo:
    hope this helps
  3. CrazyCody93
    CrazyCody93 Enthusiast
    Gresham OR
    84 Sr5 Xtra cab
    Welcome to TM! cool to see more people showing up from OR, Gonna be even cooler to see what i believe is the first pre runner toyota that i have seen! not only, your giving it some balls too! (; where at in OR are you?
  4. ffryno13247
    ffryno13247 Member
    I live in Hillsboro right now. It actually was a Prerunner I'm taking back to a street truck but I'm leaving the fiberglass on the bed so when I upgrade to the ford 9" I won't have to shorten it and I can run wider tires.
    Oh and thanks for the pic info
  5. ffryno13247
    ffryno13247 Member
  6. ffryno13247
    ffryno13247 Member
  7. ffryno13247
    ffryno13247 Member
    Sorry still trying to get a hold of this posting pics thing anyway.
    1st pic is how it is right now. the 2nd pic is of it when I got it
  8. DionTDE
    DionTDE Addict
    Preston, ID
    93 single cab 2wd
    I would like to see a better angle of the bed skirt. I think the truck would look sick if you slammed it and had some nice dish wheels that were hella flush.
  9. ffryno13247
    ffryno13247 Member
    Thats what I was planning right now first my motor swap needs to be done then the rest will kinda fall in to place. I'll take a better pic later.
    I'm planning on 17x10 in the rear and 17x8 in the front
  10. Dgerfan55
    Dgerfan55 Grand Toyotaholic
    lake elsinore CA
    94 pickup
    Looks good bro. Welcome to TM. Yea i would like to see how it looks from the back end with those sides also.
  11. DionTDE
    DionTDE Addict
    Preston, ID
    93 single cab 2wd
  12. MattMcCarthy
    MattMcCarthy Veteran
    Monterey, CA
    89 2jz
    7mgte or just a plane 7m? And I am from OR as well, by Salem. Stationed in Cali tho :(. If you can get a 1jz or 2jz cuz you can just buy motor mounts for them as long as you get a rear sump oil pan. Just saying tho.
    And we are all for sure picture whores! SO MORE PICS lol
  13. dyrti
    dyrti Veteran
    portland, or/wherever my truck may lay
    91 pickup layin' frame, and a 99 mazda b2500 (not a toyota)
    where at in the burrito are you located?? i work at freddies on t.v. highway, but live in scappoose unless im at my girls... shes ober on brookwood and baseline.
