optima battery
Discussion in 'Engine/Drivetrain' started by yota4life, Sep 20, 2009.
  1. yota4life
    yota4life Grand Toyotaholic
    lodi ca
    1991 xcab 2wd 4cyl
  2. smctoy
    smctoy Toyotaholic
    Florence, SC
    91 xcab...
    Ive used the yellow top before with no complaints
  3. Litneon
    Cocoa, FL
    94 xtra cab
    Definitely the yellow top. Everyone I know with a red top has eventually switched to the yellow top.
  4. trap
    trap Addict
    orange county ca
    92 pickup
    red tops are like stock replacement starting batteries that have more cold cranking amps.The yellow top is more of a deep cycle battery so it can be drained and recharged many more times.
    I have a red top in my truck and I have never killed it, even parked for a hour with a decent sound system watching a movie it wont struggle to start. If you plan on leaving your lights on for a while, have bags,a powerful stereo, or a inverter.. get a yellow top.
  5. carbedrn4spd
    carbedrn4spd Member
    Charlotte, NC
    89 standard cab carbed
    agreed trap i got the red one at first then took it back and got the yellow top. this was after i did some talking about it to friends, red top is for your high performance racecar like application(which if your talkin about the rn80's its not ) but if you have a lot of electricity needs for subs and what have you. then you need the yellow top.
    little testimony: dropped my truck off at the phone companys lot and rode to concord to chill and came back and my lights were still on and i could crank it no prob. so i am a fan of optima.
    pluss no nasty corrosion :waytogo:
  6. joeynational
    joeynational Toyotaholic
    PHX,AZ
    91 2WD
    i've got a red top but no air bags or huge stereo system
  7. IronNam
    I got some energizer thing under my hood... dunno the size....
    but last month or so, slept in my truck and listened to music for hours without any problems. woke up, started up and bam, works :D
  8. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Red Tops are a starting battery,the newer Yellow Tops are Deep Cycle/Starting
    I've run a Yellow Top of this type for the last 6 years,& have a 140apm alternator,also 2 pumps,2 amps ,electric fan & 120 watt headlites. Handles all fine!
    Problem is Optima batteries when very low will not recharge off the vehicle,only with a 2 amp slow charge will they come back up!
    I found the best battery is a Odyssey ( Like a Stingier,but better warranty),longer shelf life & USA made,& the only military rated battery made!!
    Will be my next battery!!:cool:
  9. ShoNuff
    ShoNuff Toyotaholic
    seattle
    75 hilux, 80 4x4
    deep cycle batts (yellow top) are best for vehicles not driven very often, with a high load (RV/ show car)
    i have red tops in almost all my cars (F'n theives). ive left 9 h3-h4 lights, CB, radio, and ignition on over night while camping. turned everything off and 2 hrs later could start the truck.
    also had the positive terminal ground out to the hood
    rolled my truck... twice
    had the batt keeper fall off and the batt fell down between the frame rails n motor, snapped the terminals off (wiring side) and bounced the batt off my front axl, then the ground as it slid to a stop from 40mph.
    all of the above has happened to the same 5yr old battery.
    NOT ONE HICCUP EVER!
  10. burnzya
    burnzya Grand Toyotaholic
    arizona city, arizona
    bodied 73 hilux
    my friend bought an old ambulance that had sat for 3 years, it had a yellow top and it cranked and started the motor.
  11. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    I run a Yellow Top ,with a 120 amp alt., 2pumps.electric fan & 2 amps.
    Problem with Opitma batteries is if down they will not recharge with the vehicles charging system. Only with a slow 2 amp charge will they come back to 12.5-13.2 volts!
    I found a better & probably the best battery is a Odyssey,same type of battery,made in the USA, & the only military rated battery. Better warranty & longer shelf life!
    Will be the next battery I buy!:cool:
  12. TheRookie
    TheRookie Member
    Boise Idaho
    77 Pickup
    My brother in Law's Red top just died, he had it in his Bagged 64 Belair, he has had it since optima offered it, sat in his garage 358 days out of the year, always started no problems.
  13. lownloud
    lownloud Toyotaholic
    Plains, Montana
    I run the red top for my starting and vehicles systems supply, and I use my yellow top that charges off a isolator to power my subs, and compressors. Topping it all of is the use of platinum coated connectors all throughout and nothing smaller than 4 gauge for wiring . . .
