OME suspension lift kit
Discussion in 'Suspension/Chassis' started by Elhuaraches, Jan 30, 2021.
  1. Elhuaraches
    Elhuaraches Member
    San Bernardino, Ca
    1984 Toyota Hilux 4x4
    How's it going,
    just wondering if anyone is running the OME complete kit for solid axel RN60. I'm thinking of upgrading my suspension later in the year. I just don't know how much of a lift it will give me
  2. QDaddy
    QDaddy Newbie
  3. Elhuaraches
    Elhuaraches Member
    San Bernardino, Ca
    6 is overkill for me since i like to daily it too mainly looking from 3-4
  4. Perkolator
    Perkolator Addict
    Placer County
    75 Hilux, 93 XCab 4wd, 02 Land Cruiser
    6" is overkill. He also has IFS, not a solid axle like you do.
    I'd keep it low as possible and probably go for the OME kit. I believe it's similar lift I got from the OME rear leafs I put on my 93 - roughly 2-2.5" lift from just the leaf springs. Beyond that I believe they just put longer shackles to get more height.
    I want to say many people even go with the heavy leafs up front if they have a winch bumper, or they modify the spring pack of the mediums to compensate. Also, I wanna say higher crossover steering kit is pretty common to follow a lift so your steering is improved over the stock push/pull that would likely get all sorts of bump-steer
  5. Elhuaraches
    Elhuaraches Member
    San Bernardino, Ca
    I do plan on loading it with heavy loads so i might go with the heavy duty ones. Im used to the ride quality being bumpy af. I just wanted to get an idea of how much it would lift it. Incase i upgrade wheel size to 33x10.5r15
