olejoe
Discussion in 'Engine/Drivetrain' started by olejoe, Jun 14, 2010.
  1. olejoe
    olejoe Newbie
    Crink pulley bolt
    Hi, say I have a 1983 Toyota pick up 22R engine and I have to replace the timing chain but I can't seem to get the crank pulley bolt loose. Is it a right or left hand thread? I have used a break over bar and a half inch impact with a chin wrench and it will not budge. Anyone have any suggestion?
  2. HALMS
    HALMS Enthusiast
    Guam
    93 reg. cab, 95 reg. cab
    This is back yard, but place your 1/2" or higher breaker bar on the driver side chassis & crank the engine, If that doesnt work, either heat up the bolt, or chisel out the bolt.
  3. CurtisZ
    CurtisZ Addict
    Lake Stevens, WA
    1978 Pickup Longbed
    I've done this on a Camry once... Worked AMAZING!!! Other idea, drop the oil pan, and wedge a piece of wood next to the crank shaft...
  4. IndianScout
    IndianScout Enthusiast
    1986 Yoda Truck
    I put a ½" breaker bar plus cheater pipe up against the frame on the drivers side, bumped the starter and it came off with my fingers..
