oil pan hitting transmission (removal)
Discussion in 'Engine/Drivetrain' started by lowrn20, Mar 1, 2014.
  1. lowrn20
    lowrn20 Newbie
    Im trying to replace my oil pan gasket but im having a hard time getting the oil pan out. I have all the bolts off but when I go to slide it out it hits the plate on the front of the transmission. Its on a 75 hilux with a 5 speed. Anyone else experience this or have any advice?
  2. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    20R im guessing? i know on some trucks you have to remove the plate from the trans (the scatter shield) and then it comes off.. its a two piece and sometimes held in place with the tranny to motor support braces...
  3. lowrn20
    lowrn20 Newbie
    Sorry, yes it has a 20r. I believe it has a 5 speed swap. From the reading I've done only the sr5 came with a 5 speed. So I just take off the engine to tranny mounts and the shield should slide right out?
