Does anyone happen to know what the offset is to our stock wheels? (2WD) Better yet, does anyone know if a +45 offset will fit our trucks?
here's a link with just about all make and model wheel pattern, size and offset, etc. great for finding craigslist specials swapping. http://www.truckaddons.com/Catalog/subpages/wheels/boltpattern_guide1.html
. . . I run 17" x 7" x +45 Tuner wheels on my 87', I have no problems with rubbing and I do run the 40 series tire . . . Im unsure of exact fitment on yours because as far as I know the rear axle width ( hub to hub ) on your ride is less than mine . . .
toyota pattern is 114.3 unless your planning on some kind of a spacer . . . my rims are 114.3 & 100's . . .
i used to run 16x7" ford probe gt's. my buddy had them, and the front needs a little center bore work. this is on a 78 with alot of front drop. it would rub the lower arms and fender lips (even after alot of rolling/flaring) at the very last bit of steering turn. they are +40 on a 7" the rear fit fine though. they were 225/50/16 all around. probably a bit much for the front but i liked it.
