First post would have made an intro but it seems more apt to fit it all into one thread. I have done all this in the past 6ish months with more to come! From the tri cities tn 91 22re 5 speed made in japan lowered 3/4 4x4 front clip .30 over .270 cam arp connecting rod bolts rv valve springs rebuilt injectors egr air injection delete cold air intake ngk plugs n wires electric fan full balanced bottom end excedy clutch marlin cralwer shift bushings clear bumper lights full cool white leds in dash and aftermarket gauges im forgeting stuff im sure here are some pics of the build so far half of it was done inside my bedroom haha alsoone of the pics is of what happend to my old motor what do yall think?
it pulls good nice idle. honestly it makes the truck. it really just makes driving it fun plenty of power to get you out of the way and for passing cars on the highway. fixing to order a header and and run a full exhaust i know that will make a big difference.
Welcome. Like the engine build with specs and photos. The block with a hole is the side, what happened there?
The block with the hole in the side of it is the original 22re with 248k. I bought it with a knock and just ran it till the bearings spun then the rod tried to escape on the way back home that day... the rod and piston are now mounted to the rear frame with the old timing chain to remind my foot to stay off the floor. i wouldn mind bags but its more work than i feel like doing in a gravel driveway. id rather just stay static once this snow clears up ill take some better pics of the bay and some of the interior..
