no start need ideas
Discussion in 'Engine/Drivetrain' started by sleepingciv, May 28, 2010.
  1. sleepingciv
    sleepingciv Enthusiast
    ok i just gave my 93 yota a wire tuck 22re
    it cranks
    its getting gas, i can smell it
    everything thing else works.
    but no spark any ideas guys????
    i didnt do anything to the coil wires or the plug for the coil either its all stock. and it ran fine before this
    and no test light to try :(
    anyone have a diagram for the wire running to the coil?
    and i checked all fuses there all good
  2. sleepingciv
    and whats this? it was bolted down with the coil stuff. does it need grounded?? just a condinsor right?
  3. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
  4. standardbyker88
    lynnwood, wa
    Yes, ground that to the body/frame.
  5. standardbyker88
    lynnwood, wa
    http://www.autozone.com/autozone/repairinfo/repairguide/repaiguideOverlay.jsp?src=http://repairguide.autozone.com/znetrgs/repair_guide_content/en_us/images/0900c152/80/06/10/f8/large/0900c152800610f8.&imageType=gif&imageName=Fig.%2027:%20Engine%20wiring-Pick-Up%201993-95%204-cylinder
    That should be the specific one for your engine bay. It differs from the 89/90 and 91/92 bays. Probably small things like an extra sensor or a wire color. If I were you, I would save all the images of the diagrams for later use. And for future wire tucks on these trucks. [​IMG]
  6. sleepingciv
    thanks
    and ur talking about the little one off the ground right
  7. sleepingciv
    well i made a test light.
    i tested the 2 wire plug pluged into the coil it self and nadda
  8. standardbyker88
    lynnwood, wa
    In that photo, bolt that metal tab to the frame/body. Clean the metal good underneath. A large self tapping screw should be fine. Or run it to a bolt somewhere within its reach. If that was near the coil and is no longer grounded, its probably the issue.
  9. sleepingciv
    just tried nadda lol
    o man this sucks lol
  10. standardbyker88
    lynnwood, wa
    Run everything you changed VS the diagram. Check all the grounds. Run a continuity tester on each side of all of your wire extensions. Things like that.
  11. sleepingciv
    well thats the odd thing cause the coil wiers are in the engine harness and it plugs righ into the ecu. didnt cut any of those., and i just pulled the ecu and all plugs are plugged in
  12. standardbyker88
    lynnwood, wa
    Make sure that all little parts and boxes that used to be grounded are still though.
  13. sleepingciv
    there were 2 ground straps in the harness one actually in the harness then one from the batery ground and there both hooked
    i just checked for power at the drivers fuse box all had power
    list is
    engine
    ign
    tail
    wiper
    gauges
    stop
    radio
    cig
  14. sleepingciv
    everything in the truck works all the way from the fuel pump to the wipers.
    but for some reason i have no spark at all.
    the injectors work also i can hear them plus smell the gas
    I have been searching for a few hours for some kinda answer and cant find anything to my problem. i even added a ground wire to the black wire that plugs right into the coil and nothing.
    mind you the truck ran just fine before this.
    all fuses are good.
    all grounds are hooked up intake. main ground from motor to battery then to the inner fender well. also there was another ground coming from the harness that is grounded to the motor also
    so any ideas?
    here is the one wire i have power at black wire red stripoe
    here is the other ground i was talking about the 2 yellowish wires. the end of this harness goes to the drivers fuse box and all fuses have power
  15. standardbyker88
    lynnwood, wa
    Well if you are assuming all is working and getting power, then factor in the coil may have been damaged. Did you leave power running to it for any length of time? Like leaving the key in the on position? With the key ON does the positive side of the coil get power to it? Take the coil wire out of the distributor cap, hold it close to a bolt on the body somewhere (to ground out) and have someone crank the motor. If the coil has power to the positive side of it, and it has a good ground...when it cranks it should spark out of the coil wire to the body. If it has power and it DOESN'T spark out, then its the coil.
  16. standardbyker88
    lynnwood, wa
    I would start at the coil, and trace backwards from there. Use that diagram. You'll get it all sorted out.
  17. sleepingciv
    battery has been sitting out since i started the tuck. put in the maf then the battery and tried to start it.
    as for power at the plug that goes in the coil no there isnt. just the pwoer at the wire at the main plug.
    so im at a total aww
  18. sleepingciv
    i know what ya mean by chasing it down and stuff but i didnt cut any wires for the coil lol this is so fubar
    and as for that diagram i cant read that poop lol
  19. standardbyker88
    lynnwood, wa
    I meant at the terminal itself. The two little wires on it. Not the main coil wire. Hopefully somebody else can chime in and help. I'm not super familiar with the underhood of the newer trucks.
  20. sleepingciv
    hope so to man, this is pissing me off. thanks for your help :)
