No heat
Discussion in 'Maintenance/Repair' started by kclin, Aug 18, 2011.
  1. kclin
    kclin Newbie
    Kirkland, WA
    1983 long bed 4x4
    I have a 1983 Toyota pickup deluxe. My heater doesn't work. I can feel the tubes going into and out of the heater core and both get really hot. But I can also feel the heater core and there is nothing Not even warm. Time for a new heater core?
  2. dillinja666
    dillinja666 Toyotaholic
    I gots no truck, for now
    Well are both pipes warm ot just 1. If your heater core was plugged only one pipe would be hot. If both pipes are hot then you got coolant flowing through it. You sure you ate touching the heater core and not the evaporate for ac, if you have one.
  3. geonbugman
    geonbugman Member
    Columbus
    93 Pick-up
    check to coolant level, steam will heat up the pipes but not enough to feel heat comming out of the vents.
  4. randy20r
    randy20r Member
    georgia
    1976 toyota pickup
    back flush it with a garden hose both ways the check it
