Nippondenso A/C mounting?
Discussion in '1976-1983 Pickup Discussion' started by johnfoster, Apr 12, 2020.
  1. johnfoster
    johnfoster Newbie
    Hey all!
    I am installing a Nippondenso dealer-aftermarket A/C unit on my ‘78, and could use some guidance on where the unit is usually situated under the glove box, and where it’s two refrigerant lines penetrate the firewall. Does anyone have an installed unit to take a few measurements from?
    Thank you in advance!
  2. Andrew Driscoll
    Andrew Driscoll Newbie
    Austin
    78 longbed SR5
    I can take some pics for you and measurements of what i'm assuming is a factory install. Ill go work on it.. but do you need one measurement specifically?
  3. Andrew Driscoll
    Austin
    78 longbed SR5
    Ill start with the picture of it mounted under the glovebox. Harder than I thought to upload pics on this site.
    This next pic shows the two lines coming out of the firewall. the first is about 4.75" and the second is about 5.5" from the side wall of the engine bay.
    Next is almost 3 inches from the middle of bottom tube to the steel lip above it. The tubes are almost 2 inches apart so its 1 3/8 inch to the lip from the middle of the top tube.
    wide shot..
    other side.. this is in the top right corner when looking under the glove box
    Probably a good chance I didn't get a measurement for you that you need... Hard to maneuver a measuring tape in there. but let me know if there is something else you need or a different pic of my dirty engine bay haha
  4. johnfoster
    johnfoster Newbie
    Doooood! That’s exactly what I needed! I have that exact unit. There’s a threaded post for mounting the rear of the unit I could use some direction on as well, if you have another minute. I’d forgotten completely about a drain tube!
    Thank you so much! You’re my A/C guru now. I’ll keep you posted on this.
    As for a dirty engine bay, this brush with a hex shaft fits beautifully in a drill with an extension:
  5. johnfoster
    johnfoster Newbie
    I just checked, and the firewall is pre-dimpled for the locations! It looks like there’s a flat spot more towards the driver for the rear-mount post as well!
  6. Andrew Driscoll
    Austin
    78 longbed SR5
    That brush is a good idea. I never think about using the drill for cleaning.. hope the mounting works out. Seems like you found the rear post mounting position. Let me know if I need to get you another pic
  7. johnfoster
    johnfoster Newbie
    Thank you! I’ll be sure to keep this thread current!
