here are some pix its a work in progress i want to lower maybe 2in and Add Intake and Exhaust any Recomendations? gonna paint her forrest green
(I'm assuming you meant lower it 2 inches from stock height) Crank the torsions and do a ball joint flip for the front. Pull the middle leafs in the rear. That's just a start and your truck won't be level afterwards, you'll probably want blocks to get the rear as low as you want the front, unless you like a raked stance. I'd do 3/3 drop or more. A 3/3 drop is pretty moderate IMO. A search of the forums should give you everything you need to know about ball joint flips, cranking torsions, and pulling middle leafs. These are all free and undoable process should you be unhappy with the effect on your ride or if you want to upgrade later. Welcome to the forum!
looks like you got a good base for a good project truck. welcome to the site. take a look around here........ you'll find some good info on what to do. me personally, i like the magnaflow mufflers on these trucks. they sound pretty good. definately get a 4-1 header if you can find one around craigslist for cheap...... intake you may wanna look at LCengineering. not really sure who makes them anymore for the 22re's anymore.
