New with 86 22r in Vegas
Discussion in 'Introduce Yourself' started by Ghostwhite, Jan 16, 2014.
  1. Ghostwhite
    Ghostwhite Enthusiast
    Las Vegas
    86 reg/long 2wd
    Hello all,
    I just picked up a 1986 Toyota 2wd Longbed with the 22r outta Utah for use in Las Vegas. Plans are to get it running tip top and pass smog then move on to a little suspension work.
    I'm generally gonna use it as a run around truck and if the AC can be saved I will end up using it as a DD during the hot summer days when I don't wanna commute on a motorcycle. It will also be my backup DD for the wife if I happen to break the 96 cherokee she drives, doing a little bit of wheeling.
    My first task it to figure out all my vacuum woes, I have a copy of the 85 service manual but it is not very detailed with vacuum lines in relation to the extra crap having to do with the AC.
    When I bought the truck it idled like crap but drove great, I found a couple vacuum lines missing or undone and fixed a few and it ran and idled great. After I got some extra vacuum line I notice some things were plumbed wrong. I attempted to get things a little more sorted and bam now it won't run well at all and I don't know how to get back to where it was.
    Anyone in the Vegas area have a 22r that I can reference in person? Anyone had a 22r w/ AC that can take some pictures for me?
    I am not going to delete anything emissions related as here in Vegas we do smog.
    Here is a photo of the truck when I rode bike up to Utah yesterday to pick it up, it was 20* out when I got to it so the warm ride home was great.
  2. 1982rn34
    1982rn34 Addict
    Bay Area 408
    1982 SR5 RN34
    Just wanted to welcome you to the TM site! I recently had my truck in the shop to tune my Weber. The Weber hasn't been tuned in almost 7 years. I hope that somebody here will be able to help you. My truck goes through Smog II where not only the "sniffer" is attached, but my truck is placed on a dyno to create a load on the engine and is tested at 15 & 25 mph. To avoid any unnecessary attention, I keep all of my smog components intact.
    Enjoy hanging out with us!
    Rick
  3. Ghostwhite
    Las Vegas
    86 reg/long 2wd
    Well I have saggin shoulders tonight, I haven't made any headway on the vacuum issues. I really wish I wouldn't have even messed with it for now but then again it has to be made right for me to pass smog. I put an ad up on craigslist to find someone locally who has a truck I can look at to get a good idea of what goes where.
    I look forward to using the AC but it really does complicate this a lot.
    I'll have to get some pics of my current vacuum setup to maybe lure in some curious minds but I left it for the night. It is idling rich enough to leave a 3 foot black streak on my garage floor, runs through the gears great though.
  4. Ghostwhite
    Las Vegas
    86 reg/long 2wd
    I got more lines figured out! It idles great again but has a slight hesitation off idle whenaccelerating
    Only have one questionable area left I think, this photo is the area and the two short lines each about 2.5 inches long(orange) and the remaining port that is plugged with a short line and screw(green). Don't worry about the fat line undone, I pulled it for the photo.(red x)
  5. Dalerman
    Dalerman Newbie
    I have a 22r with AC but I don't believe it was put in at the factory, could take some pics if it would help you out
  6. Ghostwhite
    Las Vegas
    86 reg/long 2wd
    That would definitely help, I just need pictures of the lines on the passenger side of the carb. Mainly the area above and maybe some of the lines coming out above the AC compressor.
    I found some fuel in the lines hooked up to the manifold ports and ordered a new AAP to hopefully fix that. Then I can recheck all the lines again. I have been disconnecting and swapping some around the manifold ports to help it run.
    I am trying to get ahold of a paper copy of the FSM for 1986 as it is definitely different that the 1985 FSM I have on softcopy.
    Ordered some belltech drop-spindles and 3" blocks and a felpro gasket kit. Will maybe order some rear springs and DJM lower control arms as well but then I need shocks too. I might ride on stock till they blow and then go with some bilstein drop shocks.
    I have some 16x8 rims on my 96 cherokee that I may slap on here. I want some 15x8s for the jeep as 33s and 35s are cheaper in 15s. Then I can slap the 16s on the toyota with some 205s or so.
    Here is the jeep
  7. beyondspexj
    beyondspexj Addict
    Sin City
    85 Pickup
    Nic3 bike. Just picked up a 09 cbr600rr phoenix edition myself. If you want to run classic rod tags you wont need to smog. Just limited to 4000 miles a year. But there are ways around that lol. Welcome to the site. If you use instagram you can find me under kuruption702 or hastagged pics #beyondspexj
  8. Ghostwhite
    Las Vegas
    86 reg/long 2wd
    Well I need some advice folks, the truck came with a shell but I couldn't fit it with the bike. I have the opportunity to go get it but idk if I will keep it mounted or not. It fits the truck VERY well but idk if I want to take the hassle to store it when I need it off for hauling a bike or something.
    Lemme know what your think, original picture from the for sale ad.
  9. beyondspexj
    beyondspexj Addict
    Sin City
    85 Pickup
    No imho lol.
  10. tacobo670
    tacobo670 Addict
    Las Vegas
    94 Base
    welcome
  11. Ghostwhite
    Las Vegas
    86 reg/long 2wd
    Thanks!
  12. Ghostwhite
    Las Vegas
    86 reg/long 2wd
    Ordered some more suspension stuff, got DJM 3" lower arms and belltech 3" leaf springs. I have no clue if I will be too low in the rear but if needed I can add a 1.5" lift shackle I hope.
    Almost pulled the trigger on some moog balljoints but figured I will check out what the current ones feel like when I put the spindles on.
    Not looking forward to ordering new rims and tires for the Jeep to free up the 16s it has now for the yota.
