New Wheel Fitment Question
Discussion in 'Wheels/Tires' started by KERTWOOD, Feb 9, 2014.
  1. KERTWOOD
    KERTWOOD Enthusiast
    Atlanta
    92 Street Truck
    I was looking around for different wheels to fit our trucks. I came across a Classic Muscle Car Wheel that I've always liked. Come to find out summit Racing up the street from my house has them in the size I want and correct lug pattern for our trucks. My question is what backspacing ( from ones offered at summit ) would work for our trucks for a flush fit. I've got to admit, I'm in the dark about back spacing. Never took the time to learn.
    What do ya think?
    [​IMG][/URL][/IMG]
    Summit information.
    http://www.summitracing.com/parts/are-427786545/overview/
  2. 89blaster89
    89blaster89 Enthusiast
    western wa
    93 singlecab
    not my style, i like some ofroad steelies or starions
  3. first80toyota
    first80toyota Addict
    Pacific Northwest
    '77 Hilux
    That wasn't his question.
  4. DugsulOrDie
    DugsulOrDie Member
    Honolulu, HI
    '92 SingleCab
    What's the specs on the rims and what year truck do you have?
  5. KERTWOOD
    KERTWOOD Enthusiast
    Atlanta
    92 Street Truck
  6. DugsulOrDie
    DugsulOrDie Member
    Honolulu, HI
    '92 SingleCab
  7. KERTWOOD
    KERTWOOD Enthusiast
    Atlanta
    92 Street Truck
    Hey man Thanks alot. So I could definitely run this wheel with zero problems? Once ordered they cannot be returned.
    Nice to know I can get a little wider tire to. What's your take on the looks? I think they kinda favor Starion/Conquest wheels if you remove the spinner.
  8. DugsulOrDie
    DugsulOrDie Member
    Honolulu, HI
    '92 SingleCab
    It shouldn't be a problem with those specs. The only 2 problems I can think of that might happen is the rim wont fit because the center bore on the rim doesnt clear the front hub but that problem can be sloved with an 8mm spacer. The second is the rear shock/leaf plate might be rubbing the barrel of the rim but if you're running anything less than +18 you're fine. To be on the safe side, you might wanna pick up the other rim thats +12 offset and run a 20mm spacer to clear the lug nut studs. You most likely will have to roll and pull your fenders though depending on your,drop
  9. KERTWOOD
    KERTWOOD Enthusiast
    Atlanta
    92 Street Truck
    While were at it. I got one more Wheel to ask about. Meaning would it fit? Just trying to think outside the box a little and be different. If I can settle on something else I would like to get rid of my Starion/Conquest wheels ( Base/Clear Painted, polished w/ Brand new tires )..
    I've been trying to figure out the Offset/Backspacing thing. I Know that these are 17x9.5 with a offset of +6.00mm.. I'm guessing they will work with no issues. I'm thinking they will fit like the 16x7 Crown Vic wheels with the same offset just 2.5" wider. That's giving an 1 1/4 " on both sides of the wheel.
    Pic
    [​IMG][/URL][/IMG]
    INFO: http://www.summitracing.com/parts/are-4707956155/overview/
    As always, Thanks again.
  10. Turbo Blow Through
    Turbo Blow Through Addict
    austin tx
    87 hilux
    Do it that was going to be my next choice, those or som polished torque thrusts:headbang:
  11. KERTWOOD
    KERTWOOD Enthusiast
    Atlanta
    92 Street Truck
    Disregard this question. I answered it my self.. These have the same offset as the other ones DugsulOrDie suggested I run..
    Yea I kinda like'em..
