New to Toyotas; need advice on '91 truck engine
Discussion in 'Engine/Drivetrain' started by Fogerty1970, Sep 7, 2015.
  1. Fogerty1970
    Fogerty1970 Newbie
    Looking to buy a '91 Toyota pickup. Great shape, but being a Subaru guy, I know nothing about these 2.4L 4-cyl engines. Can anyone tell me what to look for, ask about, etc., specific to these motors?
    What are the known issues, reputation, reliability, quirks of these engines?
    The truck looks sweet. Thanks for any advice.
    Chris
  2. jetas
    Usual stuff, check the oil, look for any milkshake, knocks, rattles, oil leak, exhaust leak.
    22R/22RE are pretty solid engines
  3. TwinTurboTaco
    TwinTurboTaco Enthusiast
    Space
    92 2X
    Ask if the timing chain guides have been replaced. Other than that the 22RE is super reliable.
  4. jetas
    If youre in cali make sure they smog it before you take ownership. If they dont wana smog it then haggle harder on the price.
  5. Fogerty1970
    Fogerty1970 Newbie
    Thanks all.
    Truck's in Michigan so smog tests are not an issue.
    Sounds like these motors are super tough after doing some more research.
    Again, thanks for helping out a newbie.
  6. White Trash
    White Trash Toyotaholic
    Eastern WA
    89 auto cross beater
    Pretty much the typical leak and odd rattle check will get it sorted out well enough. If it sounds like a sewing machine tapping along at idle the valves probably need adjusted. If it sounds like a bike chain that needs lube odds are the timing guide is snapped off and the chain is slowly eating through the timing cover and is about to cause the aforementioned milk shake. It's an easy fix but it can be a sweet haggling point if you need it.
  7. jetas
    Check the core support mounts for damage and the inner fender for any wrinkle in the metal.
  8. Micro Machines
    Micro Machines Member
    Portland OR
    92 xcab 22re
    Lift the passenger side carpet if it's wet, forget it. There's a spot behind the dash on the passenger side that rusts out in rainy places, also if it's been parked under trees most its life, tends to clog the drains.
