Is there a recommendation for this application? The front suspension is not really well designed. (Stiff but bottoms out easily) and the access prevents installing larger diameter shocks. I am inclined toward KYB but thought I should ask for further information. Thanks, Chuck
You can run the same 67-69 camaro spec shocks as the later models by simply clearance the hole in the lower a arm for the larger body.
