needing some parts for my 22r. Helpa brother out! Thanks
Discussion in 'Engine/Drivetrain' started by lucky_brew, Feb 15, 2012.
  1. lucky_brew
    lucky_brew Member
    I am having some parts chromed on my truck. I dont want to ship off my oe parts due to being lost or damaged as it sometimes happens. I have found most of the parts i need but here is what i cant locate...
    1983 Toyota P/U 2wd 22R Carbed w/ factory A/C
    - Dipstick tube and dipstick
    - Motor pull hook and bolt
    - bracket (clip) for hood prop rod w/ screw
    - support bracket between hood latch and bottom of core support (runs up and down) w/ bolts
    - battery hold down bracket with rod w/ screws/bolts
    - alternator bracket w/ bolt
    - alternator blade and pulley
    - intake manifold w/ thermostat housing and throttle cable brackets and springs w/ bolts/screws
    - thermostat housing (aka: upper radiator hose neck) w/ bolts
    - throttle assembly spring catch and spring (mounts to intake and holds throttle spring)
    - heater hose bracket that mounts to master cylinder (long J-shaped)
    text me at six-one-five-973-0775 , email at lucky.brew.74(at)gmail(dot)com or find me on FB at facebook(dot)com/lucky.brewer
    Thanks,
    Lucky
  2. V8_TITAN
    V8_TITAN Toyotaholic
    Tampa Fl
    89 std cab
    hey man, I have all of these things. BTW this is javier, you bought the valve cover off me earlier this month. wish you would have mentioned needing these things, could have stuffed them all in the same box !
