needing some parts for my 22r. Helpa brother out! Thanks
Discussion in 'Wanted' started by lucky_brew, Feb 15, 2012.
  1. lucky_brew
    lucky_brew Member
    I am having some parts chromed on my truck. I dont want to ship off my oe parts due to being lost or damaged as it sometimes happens. I have found most of the parts i need but here is what i cant locate...
    1983 Toyota P/U 2wd 22R Carbed w/ factory A/C
    - Dipstick tube and dipstick
    - Motor pull hook and bolt
    - bracket (clip) for hood prop rod w/ screw
    - support bracket between hood latch and bottom of core support (runs up and down) w/ bolts
    - battery hold down bracket with rod w/ screws/bolts
    - alternator bracket w/ bolt
    - alternator blade and pulley
    - intake manifold w/ thermostat housing and throttle cable brackets and springs w/ bolts/screws
    - thermostat housing (aka: upper radiator hose neck) w/ bolts
    - throttle assembly spring catch and spring (mounts to intake and holds throttle spring)
    - heater hose bracket that mounts to master cylinder (long J-shaped)
    text me at six-one-five-973-0775 , email at lucky.brew.74(at)gmail(dot)com or find me on FB at facebook(dot)com/lucky.brewer
    Thanks,
    Lucky
