need transmission help
Discussion in 'Engine/Drivetrain' started by 79*2wd, Jan 27, 2010.
  1. 79*2wd
    79*2wd Enthusiast
    Bay Area, CA
    79 Regular Cab pickup
    so my trans went out on my truck. whats trans came in these trucks? mines a five speed would it be cheaper to rebuild with new everything or find one at the junkyard?
  2. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    you should have the steel case W50. they came from 75-83ish in pickups. also in some celicas and coronas. you could run a later pickup trans if you get the bellhousing too. or the ever sought after W58 from an 81-85ish celica. they have more of an overdrive to 5th gear and better spacing on the rest of them. again. youd need the bellhousing. there are 3 bellhousings available amongst the different combos i know of.
  3. 79*2wd
    79*2wd Enthusiast
    Bay Area, CA
    so how do i know which trans is a w58 and what bell housing would i need? and do i have to cahnge any mounts and the drive line etc?
  4. 79*2wd
    79*2wd Enthusiast
    Bay Area, CA
    anyone know where i can find a rebuild kit, seals etc. ?
