Need TMs help with a 95 T100
Discussion in 'Exterior/Body' started by Malessohomegrown, Aug 19, 2013.
  1. Malessohomegrown
    Malessohomegrown Toyotaholic
    Malesso,Guam
    Hey guys It's not a Hilux or Pickup but it is a Toyota and I figured this would be the best place to check.My buddy got a 95 T100 for free that went down a couple of years ago due to a "fuel issue". I went over yesterday to check it out and went through the usual checklist and found the EFI fuse blown.Popped in a new one and it pops right away,key off nothing on just battery.I pulled all unecisary fuses to try and eliminate a ground some where.I also unplugged the fuel pump and same thing still popping.Does any body have a wiring diagram PDF for this truck.I pretty much narrowed it down to a harness with 6 wires but don't know where they go.If any body has some insight or that PDF it would really help.Thanks guys.
  2. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
  3. Malessohomegrown
    Malesso,Guam
    yeah I checked the o2 sensors for the same reason but they "looked good"there are 2.
  4. Malessohomegrown
    Malesso,Guam
    I checked the relay and it also looked ok but I'll go ahead and change that.
  5. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    What's the fuse do when the ecu is unplugged and the batt hooked and key turned to battery
