need some specs, got a project
Discussion in 'Suspension/Chassis' started by V8_TITAN, Mar 13, 2010.
  1. V8_TITAN
    V8_TITAN Toyotaholic
    Tampa Fl
    89 std cab
    I am starting to build a custom trailer, to perfectly fit my yota since I seem to tow it more then drive it, good investment haha... anyways I need to know..
    2wd single cab short bed - - -
    how much does it weigh roughly
    how wide is the body at its widest spot
    how long is it
    And what is the space in between the front and rear wheels
    Also if anyone has ANY CLUE how much the front end weighs versus the rear end lol... gunna try to distribute the weight as good as possible.
  2. thundering02
    thundering02 Addict
    Fenton 63026
    what year and option package would help weight and size info.
  3. duckyaz
    duckyaz Veteran
    Pinetop, AZ
    that, and depending on the length of the vehicle and how many axles you are gonna have on the trailer too. if you're doing a single axle trailer just long enough for your truck, you will probably want the axle right around, maybe slightly forward of your back axle so it puts the weight of your truck evenly between your tow vehicle and the trailer axle.
  4. duckyaz
    duckyaz Veteran
    Pinetop, AZ
  5. V8_TITAN
    Tampa Fl
    89 std cab
    thanks, it was going to be 2 axle but I went to the store today and saw the kits that have a receiver end for the tow truck and 2 bars that attach to the vehicle (tow bars..) they were marked down from 110 to 35 made by reese so Im almost done installing them.. all I gotta do is back up the titan to it and 2 pins she is on... gunna work on wiring a trailer pin to the tail lights so i dont have to buy any brake light kits... I did it once but ripped it out.. gunna do it again...
  6. duckyaz
    duckyaz Veteran
    Pinetop, AZ
    just pull your driveshaft when you tow it. "oh bad bad joo joo tow a vehicle in neutral. not good idea, much better pull driveshaft be safe"(in funny asian accent)
  7. V8_TITAN
    Tampa Fl
    89 std cab
    why bother ? Ive got a 5 speed.
  8. duckyaz
    duckyaz Veteran
    Pinetop, AZ
    just like rolling to a red light, you want your foot on the clutch and the transmission in gear. you don't want to roll any vehicle on a tow bar with the driveline in. short little hauls are ok, but if you're going highway speeds or long distance, it can be bad for your tranny.
  9. IronNam
    your truck may weigh about 2200lbs, but i'd give another 300lbs in there.
