im goin to install lowering blocks nd also wanted to remove a leaf but my truck has 4 u which ones to take off or which one to take off cause i dnt wanna notch it yet , i dnt wanna be tuckin in the back also
What yeat truck? Is it a 1ton? Is the axle over the leafs? Or under?. Maybe someone added a helper for loads.. Any who. Ur main leaf that bolts to the shakles front and rear. And ur lowest leaf (overload) need to stay. Start with 4in. Steel blocks. Then see if u want lower.
What wheel and tire size are you running? Also, do you load or carry anything in your truck? If you dont want to tuck in too far, a standard 3-4" drop will be about right. 3 or 4" blocks will be fine and you wont need to pull any leafs. Most 2wd trucks only carry 3 leafs in the rear unless they are a 3/4 or 1 ton pickup. Make sure to snap a shot of the rear leafs and show it to us.
Yea toss in some 4in angled steel blocks and new ubolts from summit racings website and if u want more pull a leaf.
Na i dnt load anything just a daily, i will snap a shot when i get home later but should i install blocks first or gone head nd take off a. Leaf off while im at it
