So im trying to pull a 1ton front sway bar and i cant get it removed, i have pulled the driver tbar and seperated the spindal from upper control arm removed the brace and still wont come out. Help me please.
pictures? im guessing you have issues removing it as far as an exit method is concerned.... have you tried flipping it backwards (the arms that lead to the LCA facing to the rear of the truck and snaking it out that way?)
yes snaking it out is my issue. gonna loosen the motor mounts and jack the motor up and try to snake it out on the passener side. just need alittle more clearance and ill have it.
Sawzall! Just cut it in two and it should come right out. then JB Weld it back together before you install it on your truck. Ok, maybe its best not to listen to me.
Got it out today. Took the advice and jacked up the motor and snaked it out the passenger side. Also got the rear, off to powercoat.
