Need help picking out some shocks
Discussion in 'Suspension/Chassis' started by Mufdvr, Nov 26, 2009.
  1. Mufdvr
    Mufdvr Newbie
    RIALTO,CA.
    88 TOY,SHORT BD REG CAB
    I have a 2 inch drop all around the truck should i go with some stock kind of shocks or some thing like a smaller shock
  2. TSA15
    TSA15 Member
    I ran a 3/3 drop on factory shocks for quite a while and it did fine. Technically, anytime you change the suspension geometry of your vehicle, it might be a good idea to reassess your shock choice. However, if you are not bottoming out your suspension or shocks when you hit bumps, then I wouldn't worry about it too much. I changed mine because my truck has 200k on it, and it still had the factory shocks on it. But, I put OEM style shocks (KYB's) all the way around and it still does great.
    -Nick
  3. Mufdvr
    Mufdvr Newbie
    RIALTO,CA.
    Thanks for the info
  4. TSA15
    TSA15 Member
    no problem. I hope that helps.
  5. Evolmotorsports
    Evolmotorsports Veteran
    SCV cali
    1987 RN50 Hilux
  6. Badlux
    Badlux Enthusiast
    Kaneohe, Oahu
    87 xtra cab
    ^^^what he said.
