need gas pedal for 76
Discussion in '1976-1983 Pickup Discussion' started by Jim Thompson, May 18, 2023.
  1. Jim Thompson
    Jim Thompson Member
    Hi, I cant find a gas pedal for a 75-78 pickup..any ideas?
  2. jetas
    Do you need the foot pedal part or the actual metal piece that mounts on the firewall
    Jim Thompson likes this.
  3. Jim Thompson
    Jim Thompson Member
    I Need the foot pedal , has the loop on the back , about 9 1/2" long
  4. jetas
    Let me check my box of spare parts. I may have one
  5. fred heath
    fred heath Addict
    Raleigh, NC
    Backyard repair. My hinge at the bottom of the pedal completely rotted away.
    Rather than try to find a replacement, I attached the pedal to a 6” T hinge. I simply drilled two holes in the pedal to match the factory holes in the hinge. Then added machine screws with nuts to hold everything together. Spray bombed new metal flat black. Attached hinge to the floor pan with sheet metal screws.
    Not factory beautiful, but works really well.
  6. Jim Thompson
    Jim Thompson Member
    Nothing wrong with the one we have, i need the one from a 75-78.. we are changing the gas pedal and linkage set up in a 74 we are working on, we have all the linkage ,just not the pedal , the 74 pedal is only 8" Long and doesn't have the loop for the rod
  7. jetas
    My truck is a 72, this was the pedal that was in it when i got it, truck already had a 20R swapped in. DM me if you're interested
  8. Jim Thompson
    Jim Thompson Member
    Not sure if I DMed you? I tried , I want the gas pedal
  9. Jim Thompson
    Jim Thompson Member
    did you get my DM?
  10. jetas
    No sir. I still gotta dig thru the parts bin. I'll send you a message tomorrow
  11. Jim Thompson
    Jim Thompson Member
    DM me, since I guess I dint know how to DM you , ok
