Need bag kit for $1200....
Discussion in 'Suspension/Chassis' started by Litneon, Mar 21, 2008.
  1. Litneon
    Cocoa, FL
    94 xtra cab
    Got any leads on a decent setup for around $1200? I've already notched the rails in the rear, would prefer Slam Specialties bags, but I'm open to suggestions.
    Need the 4link and FBSS is preferred. Not to actually use the side to side, but to control body roll using 8 valves instead of 4.
    Is it possible to do with my budget? Mind you, I can do all the fab work.
    I checked all the sites I could find, but I couldn't find one that would let me build a complete setup.
  2. smctoy
    smctoy Toyotaholic
    Florence, SC
    91 xcab...
  3. DietoRemain
    DietoRemain Member
    suicide doors is the place... but honestly that price is unreasonable. I paid $1600 for my parts shipped that didnt include lines and fittings which i got hooked up with by a friend haha (true hydraulic hose, and really good fittings, not to mention marine grade wiring, yeah my trucks over kill).
  4. ChOpPeD~N~DROPped
    ChOpPeD~N~DROPped Enthusiast
    West of Atlanta!
    94 Extended cab
    I prefer the CanDo reverse cantilever 4-link myself. I paid $550 for it shipped. I ordered the rest of my stuff from The Bag Shack. If I could go back and change anything I would have got CanDo's front bag brackets because they're already pre cut and everything. I've got slam bags, GC Xtreme 1/2" valves, AVS aluminum tank, 2 Viair 380's. AVS switchbox. KP gauges. and I've got probably between $2000-$2500 in it. But I did price shop and wanted top notch stuff to do it right the first time. Another thing that will eat you ass up is brass fittings especially push ins, Luckily my grandfather and great uncle are both diesel mechanics and had a majority of the fittings and all my 1/8" line. I paid $50 for 100' of 1/2" line at a plpace that sells semi parts. And I'm sure steel is ridiculous too, we already had all of the steel I needed. Welding wire isn't cheap either.
  5. DietoRemain
    DietoRemain Member
    Slam bags all the way. RE7's all the way around here. dont ask me how they fit in the front... :D they just do.
    But yes brass fittings kill.
  6. Litneon
    Cocoa, FL
    94 xtra cab
    Yes, I talked to Michael at Cando. I guess $1200 is a bit low. Back to the drawing board. There are less expensive ways to do it, but less expensive isn't always right.
    I'm looking at about $2200 for everything shipped. I guess it's time to see what else I can sell...:eek:
  7. ChOpPeD~N~DROPped
    West of Atlanta!
    94 Extended cab
    This is my theory, if you don't do it right the first time then you're gonna spend more money in the long run fixing the **** that you should've done right the first time. It's like a guy told me once when I was guitar shopping "If you just keep buying cheap guitars then you're gonna spend more money on crappy guitars that don't last, just buy a good guitar now instead of blowing money on cheap guitars." If you've gotta save for it then save up for it, or if you have a problem saving for it(like me) then just do it Johnny Cash style, one piece at a time. But the reason I prefer the CanDo 4-link is because you can keep the stock gas tank location and you can keep the leaf springs in until you get the 4-link welded in then take them off.
  8. lownloud
    lownloud Toyotaholic
    Plains, Montana
    The light is burning
    I guess Ive caught the bug as well, and want to invest in a quality 4 bag system for my 1987 toyota pickup standard cab. Ive seen tons and tons of aftermarket stuff and other kits all over the place, but if Im going to do it, I wanna do it right the first time, no, taking crap back apart, mending, or rigging sh*t. Im sorry if I am jumping in here, but, I have $2500 saved for parts. I currently have belltech 2" drop spindles and nitro shocks up front, the back is blocks, Im running 17" 205 - 40's with +45 offset ( tucking wont be a problem front or rear, that I know of, all four clear the wells ), I want to keep the stock gas tank location and am open to options on the arms. I wanna know also, Who you guys would recommend ? I dont plan on bodydropping my truck ( YET - or for this project ), I just wanna get lower and be able to " play ". So, without wearing it out, Who should I talk to ! I have the capability of torch/ grinders/welder ( me :) ), tools gallore, jacks, paint equipment and more. Im not going for show, Im going for clean & go ! Lets hear you !
  9. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    If you plan on leaving the fuel tank in the stock location I would do a set up like Seth's. Looks real clean & says rides great!:cool:
  10. ChOpPeD~N~DROPped
    West of Atlanta!
    94 Extended cab
    CanDo Reverse Cantilever. Tons of lift and fairly simple to install and you leave the gas tank in the stock location. great flippin' product!
  11. lownloud
    Plains, Montana
    I like . . .
    I like it ! Ive been reading Seth's thread like the mini truckN' bible, I like the idea of keeping the gas tank in its stock location because I dont wanna fill up my bed with tanks and compressors, I dont haul anything, but would prefer to have it tucked away. I am going to try something else as well, Im going to either have the bed tilt outta the way so I can access all of the system if I need be, which way or how it lifts and where I dunno, still thumbing over pics and scribbling ideas down. So what say you on the front ? I have the drop spindles and intend on keeping them if possible. I want to keep it simple yet functional and dont wanna have tons of camber when I lay it out . . .
  12. DietoRemain
    DietoRemain Member
    Negative camber is fun. :D
  13. ChOpPeD~N~DROPped
    West of Atlanta!
    94 Extended cab
    it's fun if you like to see you're tires wearing on the insides. I've gotta buy drop spindles for mine because I would rather not replace my tires as often and it will lay out all the way. From everything I've read drop spindles are a must if you wanna lay flat out, also another thing that helps out a great deal is new control arms. The only thing I would've done differently to my truck is I would've bought my front bag brackets from CanDo because they're already cut to fit our trucks unlike the universal brackets that I bought.
  14. DietoRemain
    DietoRemain Member
    Yeah its cool dude. The pretacos are easier.. I have a taco. No one makes spindles for tacoma's that dont cost insane cuz they are all custom.. so it sucks for me but whatever I drive at a decent height and my cambers not too bad.
    Anyway gas tank in stock location is great but definitely LIFT it up. mine was a custom modification to the crossmember and it came out clean and its way above the frame so i can drag all day and not blink. SLAM RE7's all around= best :D
    Dont ask me how they fit in front.
  15. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Moving the tank & doing a forward link set up was a must for me ,as very book on suspension says the same thing,you can not change physics. And handing was & is a important part of my build!! I know there are people who disagree with reverse/forward link set ups. But physics are fact,if you push your vehicle,you want it to handle!! Ride & handling are very thing!!
    So research as much as you can before you start any part of your build,so you can do it once & do it right!!
  16. Litneon
    Cocoa, FL
    94 xtra cab
    Hey Truckaction, just out of curiosity, what book are you reading on suspension geometry? I honestly haven't found anything written by anyone (who is someone authoritative) that actually addresses the forward/reverse 4link designs.
    I want to find something reputable to read...
    I am leaning towards the reverse 4link myself. Mind you, I can't prove or disprove the physics behind the two, and I would love to read it from an engineering standpoint. I have designed and built 4x4 4links for a few years now and I haven't been able to picture in my mind why the reverse shouldn't work.
    I have however found many Forums, which I can't take seriously because of the bickering and the lack of proper grammar and spelling.
    I need facts...... Oh, and thanks....
  17. Litneon
    Cocoa, FL
    94 xtra cab
    Search and I shall find.....
    http://www.minitruckinweb.com/tech/suspension/0606mt_rear_suspension_mini_trucks/index.html
    And I quote (make sure you read the whole quote before you say anything):
    "Forward, reverse-what's the difference? A forward-facing four-link transfers energy to the chassis, planting the rearend under power and a small amount of anti-dive under braking; and it can be tuned infinitely for a specific purpose. A reverse four-link, on the other hand, should only be used as a compromise. They will drive fine and turn corners and stop the car without too much upset, but again, as I've stated several times before, "the confines of the mini-truck do not leave much room for dangerous designs." On top of that, there aren't bucket-loads of horsepower pouring out of the average mini-truck and if so, it usually doesn't make it to the ground."
    :cool: "Another saving grace of the reverse orientation is that roll steer is almost always roll understeer, making the truck feel stable in corners. Also, the pinion angle, when properly designed, is kept well within working limits. The point is, the reverse four-link works. It holds the truck off of the ground and keeps the rearend under the truck.":D
    Nuff Said
  18. lownloud
    Plains, Montana
    anything works if . . .
    I have read similar things on reverse 4 links. Hell, I consider a 6 - 12 inch lift more unstable than any drop. every highlift Ive rode in makes me feel like Im either riding in a tank or about to grab the door handle to jump out. As for the reverse setup, I have never driven one, never driven a forward 4 link, or even a bagged, so i guess my opinion on these setups dont amount to much. this being said, truck will be driven 90 % in town, speeds less than 35 - 45 miles and hour, stock power will be used with mild carb and exhaust upgrades, NO bodydrop, and will maybe be sometimes driven outta town. My inquiry is for loads of lift, cost effeciency, safety, and air capability, I will not race nor plan on it, shesa cruiser not a dragster, and definently not as built as some of the engines out there. Im not saying anyone is wrong or right, I just want the best ride for how I drive my truck. ALL opinions and recommendations considered. Thank You !
  19. DietoRemain
    DietoRemain Member
    I took my truck to over 90 on the freeway and it was still fine. yes with a reverse link. Honestly do it right and it'll be fine for you. As it is for me.
    Why bother hassle with the forward link for something that you dont need it for?
  20. ChOpPeD~N~DROPped
    West of Atlanta!
    94 Extended cab
    My reverse 4-link works fine, I haven't gotten to drive it much yet but from the time I have drove it it works very well. The only thing I have to complain about it the lower back brackets, when I lay it all the way down with the front picked up the brackets drag the ground, I'm gonna run some kind of drag plate under the brackets so I'm not dragging the brackets and bars to pieces.:D
