I installed a new head on my 22re and if youve seen yourself te vacuum lines are a pain in the ass. I got everything good to go except one connector at the front of the motor. Its in the same bundle as a green cap sensor along side the freen is a black capped sensor, and the bundle also carries a bigger black cap sensor that goes to the upper manifold just to the right of the intake port. Its a single pronges sensor grey in color. Please get back to me asap. Thank you kindly
the black one looks like the TPS connector that goes to the right of the throttle body. the other grey one i believe is either a temp sensor connector, however some motors did not have this sensor and is not used, its just there as part of the harness and will not affect anything.
Aweeee that makes perfect sense!! I dont have a/c... Haha thanks a lot its good to know im not missing anything after this build. Thanks again!
