Mystery Vacuum Line? '77 truck
Discussion in 'Maintenance/Repair' started by zatoh, Feb 13, 2011.
  1. zatoh
    zatoh Newbie
    Help Toyotamini'ers!
    Vehicle 1977 RN28, 20R, AC, 5 Speed, LB
    So I was trying to trouble shoot a rough idle that I have. The truck has been garaged for the past 6 years and I start/drive it every 2 weeks or so. I'm due for smog so I was getting it ready. I found that I have a vacuum line that doesn't connect to anything and was wondering if anybody knew where it goes. Right now I have it plugged with a bolt but that does not seem to make a difference.
    As you can see there are 3 hoses running off this particular fitting. The line runs between the carb and head to the back of the engine and stops.
    I have also put in gas treatment and am trying to run through this tank of gas in case it might be old.
    Any help would be greatly appreciated!
  2. farmorejustin
    farmorejustin Member
    Indianapolis, IN
    78 long bed
    Well that's a Thermal Vacuum Switching Valve (TVSV) I can tell you...the hose you point to probably is hooked up to Automatic Switching Valve (ASV). I'd have to see your engine bay to see your setup, but yours shouldn't be extremely different from mine (unless your in CA). Do you have access to a vacuum diagram from your year?
  3. six7one_KDR
    six7one_KDR Veteran
    From Thee Island of GUAM,Live's in WASHINGTON / NO
    1976,1979,and also YES a 1973 HILUX
    if im not mistaken those go to the air cleaner...
  4. dillinja666
    dillinja666 Toyotaholic
    I gots no truck, for now
    winar!
  5. randy20r
    randy20r Member
    georgia
    1976 toyota pickup
    it goes to the bottom of the air cleaner for the exhaust heat pick up tube
