my yota goes every were!!!!!!!!!
Discussion in 'Suspension/Chassis' started by suzuki07, Apr 6, 2009.
  1. suzuki07
    suzuki07 Enthusiast
    baytown, tx
    92 isuzu , 92 yota, 07 suzuki
    dont really know if is a problem or old toyotas feel like this. when i drive on a bridge the wind make it move side to side. i changed the center link , 2 inner ball joints, and the steering damper; what ells can replace to prevent from doing this.:shrug::shrug::confused:
  2. nvrenufedge
    nvrenufedge Grand Toyotaholic
    Caldwell, ID
    bagged '93 std cab
    I notice mine catching the grooves in the road when the tires are low.
  3. 88Sandshark
    88Sandshark Toyotaholic
    Lake Elsinore, CA
    Mine feels the same way sometimes, but then again, I've got the 4x4, so crosswinds are very fun.
  4. the_general626
    La Mirada, CA
    low tires cause the truck to pull to one side or the other... as for winds, if theyre strong enuff theyll pull u to one side also... its because the trucks are lighter
  5. Toyota530
    Toyota530 Veteran
    94 toy xcab
    mine does that too hehe, omg and it insane on on fussy roads, cant drive fast.. its normal if you got thin tires
  6. lownloud
    lownloud Toyotaholic
    Plains, Montana
    Ditto on all the above, add to that - Welcome to the world of minis or light duty trucks, grooves, winds, semis passing and tires/pressure all work hand in hand to create a unique driving experience. Consider the world filled with big rigs and heavier traffic and sometimes alot of it, and you got the wandering. Me . . . Ive just learned to grin and bear all the fun that roads have on my mini, add to that the fact that Im running 40 series tires and can set er down to the pavement as low as my nerves will let me. . . Now thats fun . . .
  7. 88Sandshark
    Lake Elsinore, CA
    Wish I could get mine that low sometimes, be more stable at high speeds. 4x4's are nice, but low riding is not a specialty of them.
  8. burnzya
    burnzya Grand Toyotaholic
    arizona city, arizona
    bodied 73 hilux
    my 04 mustang gets crazy in a crosswind. it makes me look like i'm drunk. my s10 doesn't seem to have that problem though.
  9. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    yea, cross winds are a bitch in the 4x4's........... my 85 with a 6" lift, and 35's was like a sail up there catching all the wind. most of it has to do with the weak front sway bar.... they dont do much on the 4x4's and there's alot of leverage ont them. also, these trucks have alot more ground clearance on them than standard cars so the wind gets under them too and destabilizes them..... its common...
  10. IronNam
    jsut make your truck lower.... :D
    cross winds are pretty intense.... also the lack of power when going headwind.
    I do about 80-90 average on the highway, truck will need me to point steering wheel at least 5 degrees left or right sometimes, it may just also depend on the road's "tilt" angle (bank angle i mean). but when a huge hard wind hits, it will sometimes move a feet left or right.
    and my truck is only 1" lower up front... and extracab, more side space..
  11. Sam78
    Sam78 Enthusiast
    Oceanside
    78 toyota longbed 5speed 20R
    i love my old little toyota
  12. toy_spd
    toy_spd Addict
    So.Cal -
    92 SR5 V6 Extra Cab
    check for play in the wheel bearings, mine had some miniscule play and i fixed it and took care of the problem
  13. suzuki07
    suzuki07 Enthusiast
    baytown, tx
    Thanks for the replies, you all say is normal but on my 92 isuzu I haven't expirience that.
    Maybe because I have 16x7 and baggs ,don't know but am trying to get some new wider wheels and if the going
    Allover the road stop all let y'all know. Don't want a cop to stop me because my truck make me look drunk.
  14. suzuki07
    suzuki07 Enthusiast
    baytown, tx
  15. EM1JIM
    EM1JIM Member
    oh good to hear about the rest of you, i thought i was just me when i came accros some winds :eyecrazy:
  16. HaNd_SoLo
    HaNd_SoLo Enthusiast
    Sonora, CA
    1987 xtra cab long bed
    Check your idler arm, too.
