Yesterday i did this nifty little upgrade on my other Toyota. I know it's not a truck but I figured some of you fellas would appreciate it anyways. My car is a 2001 Camry LE Gallery Edition Parts: 1. 2008 Highlander Front Rotors (Duralast Part #44607 ) x2 at $52 each. 2. 10-13 Lexus RX350 FWD Brake Front Calipers or 08 Highlander Calipers x2 at $51 each (Ebay). 3. Wagner ThermoQuiet Brake Pads (Part # QC1324) Retail Price $85 (I paid $47) for the set. 4. TechnaFit Stainless Steel Brake Lines $115(Part # TOY-1012) (Techna-Fit Online Store) Walkthrough You NEED to have at least 17" rims to do this mod. Here is a shot of my wheel with original brakes on it. Here, my original rotors have been removed. Be sure to bend the backing plate back a little (on top and on bottom). It bends pretty easy and will rub on the new larger rotors if not bent back. Here Highlander/RX350 rotor is installed and the Highlander/RX350 caliper bracket mounts in the same bracket mount and I used my original bolts. Original caliper is in background left out of the way. This shows how Highlander/RX350 caliper simply mounts on existing mounting points and using Camry bolts. Here is a shot of everything installed including steel braided lines installed. You could use your original Camry brake line if it is still good. I chose to just do this upgrade. Also be sure that your backing plate doesn't touch the rotor, just bend it back more if it does. Finally here is the rim installed. If you look closely the caliper just barely fits (17" rims). M
