this is nowhere near showing real time of what has taken place with my truck, but it is a recollection of what all has been done to it since I got it. I believe I got it like 1.5 years or 2 years ago. Sat like this for probably 5 or 6 years. Few fuel filters, lots of language, and some pissed off nights, I drove the truck home on the old gas and oil haha. Front Dropped on the balloon tires. Back Dropped. Dropped on my probe 16's. These are staying, no need for bigger! Last day of being static, well fully static. This is on the way to innovative customs in Meridian MS. Some great people. Jamey and Don do great work. Their work. Layed Out Us at Scrapin
loaded up to get stock floored on September 4th roughyl. backhalf full frame first round of front bags boxed and plated uppers. Gusset First run control arms. 7/8 drop mounts. 1 inch would hit drag link on mine.
he notched and "sleeved" this tab to allow access to the fill plug crossmember behind cab gas tank and air tank mounting
for whatever reason i am not paying attention at all today. can someone move this to the 84-88 forum.
It hasn't been easy, that's for damn sure. Stressful as anything i've ever been through, and not because the work being done.
my last bag job before i went stock floored rode just fine. nothing wrong at all. i was very happy with the setup. nothing should change with these.
sweet thanks. been thinking about what to do with the front. and the lower radiator hose will hit the strut rod bracket after body droping and zing. thought about doing something like you had at 1st with the bent tubing, but wasnt sure how it would ride, dont want it to shake. so thaks so much for the info. gonna pass the info on to someone else here, he is having same issue. THANKS BRO
it will shake if you dont have it alligned properly but the guys who did it just roughed it in at the shop and I never once had a problem.
Sharp man!! I like where the body was cut around the tranny. I've never seen it cut there before and it looks real good.
you mean for the tranny tunnel? we got lucky, the top part was cut out to lay the truck out on the trailer and then we cut it apart to fit the tranny in and learned the rear top piece actually fit back in there so we just had to fit the side pieces. It will get a full sheetmetal floor next winter though. Have some plans.
