My headlights don't work
Discussion in 'Maintenance/Repair' started by mandinvw, Nov 27, 2011.
  1. mandinvw
    mandinvw Newbie
    1979 Toyota Pickup 1ton
    My headlights stopped working, but my signals work, and the pop is heard when turning the switch.
  2. 1976yota
    1976yota Newbie
    Tucson Arizona
    1976 Toyota pickup
    that happened to me and i had to rewire my headlights
  3. eurofreak2002
    eurofreak2002 Toyotaholic
    B-town 208
    Bulbs burnt out??
  4. mandinvw
    mandinvw Newbie
    I checked all my fuses and no luck. Now my clutch goes all the way to the floor with no resistance, and no gears go in.
  5. Malessohomegrown
    Malessohomegrown Toyotaholic
    Malesso,Guam
    first about your head lights. Are both of them not working. Try messing with the wires while the lights are on. I think its a ground wire. You can test this by grabbing a short piece of wire and wrapping one end around middle prong of the three prong plug on the back of one of your headlights leave the plug on coming from the truck and put the other end of your wire on a solid engine ground. Make sure your light switch is on. As for your clutch pedal. Your clutch slave is probably out. Its an easy fix. It is located next to your starter. Look for fluid that has leaked out on the ground.
  6. Malessohomegrown
    Malesso,Guam
    Take a multi tester or a test light to the plug going into one of your headlights and make sure you're getting power first. If you are its the ground.
  7. mandinvw
    mandinvw Newbie
    I got the clutch working now, i just bled the plug in the tranny and its running like a champ. Havent figured out the lights.
  8. randy20r
    randy20r Member
    georgia
    1976 toyota pickup
    new switch time
