http://www.youtube.com/watch?v=gYksrgwnMHU Here is the link after the first start. I still haven't done any fine tuning and adjustments. I will be getting to that this week. What you all think, I know I still have to do all the little things that will make this motor get the full potential. What do you all suggest, I will be borrowing my friends Timing light to make sure the timing is set. I also will get the Carb Sync that I ordered tomorrow. I will post more videos later.
Looks ands sounds real good. Keep it coming. Just so you know, you don't have to start a new thread everytime you have an update. Just put all your updates under your original thread. It kinda gets confusing. Lates!
Nice setup. I have a stage 5 Pro Stroker. If you need help setting up your carbs let me know. I have my timing set at 32 degrees total. If you have Weber 45 's your idle jets should be changed to 60 with 2 3/4 turns out. After you sync the carbs set your idle at about 900 RPM. Put fresh plugs in so you can check the color. Watch #1 cylinder, it might run a little lean. Good luck and have fun.
