My Bagged 94 and my 90 #6 Ministock race truck
Discussion in '1989-1995 Build-Up/Project Threads' started by Ministock6, Jun 11, 2015.
  1. Ministock6
    Ministock6 Member
    Lake Mathews CA
    1990 Lucas Oil Regional Ministock #6, 1994 Bagged C-notched and Shaved parts truck turned play toy
    Thought I would share both my Yota's with the site since it has helped me with so much info on both my truck's!
    94
    Bagged Frt/Rr want to Z the front, so if anyone local to Riverside Lake Mathews Ca area hit me up! I'm interested in finding out how much it will run for good quality work.
    ESR 17"
    C-Notch in the rear
    4x4 frt fenders
    Had the muffler and cat tucked
    Door handles came shaved with door poppers but I can only get driver side to work. Project's are never ending!
    90
    Ministock
    Class is pretty much how it sounds you take a stock pre 98 or older truck and add 2.5" of shock per wheel and limit the shock travel to 9" in the front and 11" in the rear and motor must remain stock EFI/Carb are both allowed. The rules are on Lucas Oil Regionals Web site.
  2. Ministock6
    Ministock6 Member
    Lake Mathews CA
    My Ministock
  3. Ministock6
    Ministock6 Member
    Lake Mathews CA
    The office view of my Ministock
  4. Ministock6
    Ministock6 Member
    Lake Mathews CA
    Before the wheels playing the switches on the bags so I knew what they did.
  5. Ministock6
    Ministock6 Member
    Lake Mathews CA
    Picture from my first race at Glen Helen
  6. Mikerocosms
    Mikerocosms Veteran
    New Mexico
    1990 22R Pickup
    Cool rides bud. I take it you bought the bagged one already bagged and with some mods done to it?
  7. Robert m
    Robert m Addict
    Apple Valley, Ca
    '94 single cab, 22re, 5spd
    Nice! You're collecting the whole set!
    31'' generals on the ministock? Do they rub on the inner fender/firewall at full bump? Are you on stock leafs in the back?
  8. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Welcome & nice ride rides!!:cool:
  9. twizted1
    twizted1 Addict
    NORCAL
    '89 xcab 2wd
    dign those esr 17s nice wheels look great on the truck!!
  10. Ministock6
    Ministock6 Member
    Lake Mathews CA
    Thank you! Yes it was, I was going to just part the truck out for my race truck. But I got it running and cleaned it up some. And before I knew it I was having fun driving it..!
  11. Ministock6
    Ministock6 Member
    Lake Mathews CA
    31" Mickythompson, but I'm going to race on 27" these are just my back yard testing tires. They don't rub when turning, they rub at full bottom out, especially since all the body mounts have been removed and the whole cab was moved back an inch and down, so now the cab is attached to the chassis. We also cut the firewall wells back and added steel where it was needed. Stock leafs in the rear with one spring pulled. the truck is really lite.
  12. Ministock6
    Ministock6 Member
    Lake Mathews CA
    Thank you
  13. Ministock6
    Ministock6 Member
    Lake Mathews CA
    Thank you! They were a steal and I'm stoked on how the truck sits with them!
  14. Robert m
    Robert m Addict
    Apple Valley, Ca
    DAMN! 27s and a 5:30 gear out back? That thing has to be singing at speed. Do you even have to use 1st gear?
    And if you're getting 11'' of travel out of the stock leafs? :brickknock: I desperately need to redo my rear setup. With deavers, I'm getting a hair under 14'' strapped.
  15. Turbo Blow Through
    Turbo Blow Through Addict
    austin tx
    87 hilux
    Both are awesome I would love to have a long travel truck but I have enough projects as it is
  16. Ministock6
    Ministock6 Member
    Lake Mathews CA
    You have to remember we are racing on a dirt track, and sliding and controlling the slide is what makes you fast in this class. Also this class is know for who ever lets off the gas first loses. I only use two gears in the race. If you use more your truck isn't set up right for the track.
  17. Ministock6
    Ministock6 Member
    Lake Mathews CA
    This class requires a max rev limit of 6k.
  18. Ministock6
    Ministock6 Member
    Lake Mathews CA
    I know what you mean! I also have a RZR XP4 that I use as my long travel ride. The Yota's cost to much to get the ride I get out of my RZR.
  19. Ministock6
    Ministock6 Member
    Lake Mathews CA
    Took the mini out for a Sunday cruise! I love the looks it gets now with the new ESR wheels.
  20. Ministock6
    Ministock6 Member
    Lake Mathews CA
    Man what a difference wheels and tires can make...
