i know im gonna get ripped for not starting a build thread yet, but id rather get work done than talk about doing it haha. but here are some pics of her. i bagged the rear, wishbone three link. dropped the torsions put 18s 4wd fenders and just sprayed it all flat black a few days ago. the rear prepped for paint sprayed dropped the front
Me to. I'm pretty sure they are aftermarket also since there are so many bolt patterns drilled into them.
hey guys thanx for the posi feed. the wheels are 18x7.5 kyowa kr206. i got them off brian aka BEEFED about 2 or so months ago. and im in the works of collecting all my parts to do the 01-04 front conversion, all i need is the core support and im ready.
not to bad the mounting width on the taco compared to pre- is about a six inch difference, so i made brackets to bring each side in 3 inches and it went right up
if you door the truck, you'll only be able to run 17's under the stock fenders/hood. if you mod the fenders then 18'. to fit 20's would throw the look way off in my opinion.
ill snap some tomoro ive decided to go flat rocker when i do it. i think ill leave about 3/4 of an inch below the door. and im going with the 01-04 fenders and hood as well so if i have to mod em i will but im hoping not.
here it is. its a couple pieces of 1/8in. strap. two pieces have holes 3 in. apart to bring the bracket in on each side one goes trom the top of the bracket and wraps down for streangth. i have stoop and hopped on my bumo=per and it has not even budged.
