my 83
Discussion in 'Suspension/Chassis' started by beradg252, Oct 17, 2010.
  1. beradg252
    beradg252 Member
    Shell Beach, CA
    83 SR5 Longbed 2wd
    here are some pics of my truck after i put the rear blocks and shocks on i need to do something with the bump stops and now need to do the front.... How should i do the front?
  2. beradg252
    beradg252 Member
    Shell Beach, CA
    83 SR5 Longbed 2wd
    i found the bolt with the two lock nut on it for the front torrision bars how do i go about lowering the front?
  3. V8_TITAN
    V8_TITAN Toyotaholic
    Tampa Fl
    89 std cab
    you loosen the bolts ! lol. simple. the lower you want the loser you go !
  4. speeddream
    speeddream Member
    Off topic, but can you tell me where you found your new chrome headlight assembly with the clear corners? I search everywhere and cannot find. Thanks
  5. beradg252
    beradg252 Member
    Shell Beach, CA
    83 SR5 Longbed 2wd
    i actualy came up on them at a junkyard off an 82 4x4 idk if it was sr5 or not????
