I open my hood today, and found that the four bolts on the top if the motor was leaking a bit of oil, not much but a lil, could it be its little over filled or not tighten up enough or maybe the seal are messed up? I havnt done anything to it because i'm not much a mechanic and dont want to mess something up, so what do you guys suggest or has it happen to you? The Picture below shows what i'm talking about, its not my truck but demostrate the area in orange circles.
true....... replace them. make sure to clean off the area around the seat before you put in new ones.tighten them down and your oil leak issue should go away
