My 1994 4x4 Build
Discussion in '1989-1995 Build-Up/Project Threads' started by Roland Deschain, Sep 6, 2021.
  1. Roland Deschain
    Roland Deschain Enthusiast
    81A25907-3B10-4F18-B4E7-F5788DE3E80A.jpeg 02B5241E-763A-403A-BA42-B1563F3C0734.jpeg Recently purchased 1994 4x4 Toyota pickup, 22RE, manual transmission, A/C and P/S. Currently has a custom built flatbed that I plan on selling and replacing with a standard bed. A few pics of it as is. D8EAAA20-EA3A-4A7F-9B70-62BA7EAE976E.jpeg
    Erwin Merida likes this.
  2. Roland Deschain
    Started on steering today, replaced idler arm, inner and outer tie rods ends and sleeves. Still need to replace pitman arm but the puller I had wouldn’t budge it. Going to have the alignment shop replace it when I get front end aligned.
  3. Liquidhandwash
    Liquidhandwash Enthusiast
    Northen VIC
    1980 diesel
    You can get your wheel alignment very straight with a couple of string lines going from the rear wheels to the front.
    Make sure the steering wheel is centred and straight and adjust the toe-in so you have about 1-2mm on each side.
    Roland Deschain and Erwin Merida like this.
  4. Roland Deschain
    Got the antenna installed last night. 9EF008A7-515B-49DC-9893-68C4F8999FF8.jpeg 11EA2D11-9A9A-4246-B9A1-E15A3911F082.jpeg
  5. Roland Deschain
    B40E10FD-08C9-440E-B510-D2E35A4E7B9F.jpeg Ripped out the old carpet last night. Ordered replacement from Lund Industries, guess we’ll see if it good to go.
    BB8A9B60-59C9-44FA-8E4D-F3331CA95F0F.jpeg 989F759A-6339-428C-B44E-E12FD3ADBCE9.jpeg
  6. Erwin Merida
    Erwin Merida Toyotaholic
    Long Beach, California
    LEXXXI - angry '93 ShortBed
    Nice, some killmat would be awesome under the carpet.
    Roland Deschain likes this.
  7. Roland Deschain
    Going to try to get the interior pieces painted this weekend.
  8. Justin Danger
    Justin Danger Toyotaholic
    Bay Area Peninsula
    Making nice progress! Make sure you clean theinterior pieces toroughly. I don't know if previous owners of my truck used interior polish or what, but the first time I painted things it ended up with suuuper bad orange peeling. I then washed everything with acetone, and the paint laid down fine after that.
  9. Roland Deschain
    Thanks, I’ve washed everything with soap and water. Then I wiped it down with wax and grease remover. Probably clean everything again, also have the plastic adhesion promoter to apply before the paint/dye. Hope it comes out decent.
  10. Roland Deschain
    Got the shocks installed front and rear.
    27205360-C622-4CBA-AF44-FAEED8546373.jpeg FA0230CD-DE74-42C0-8372-9761ED3BA6A6.jpeg
  11. Roland Deschain
    Also replaced sway frame bushings and links, went with Energy Suspension. Was getting late and I couldn’t figure out why the links wouldn’t line up. There are three threaded holes, I was using the farthest one back☹️. After that it went smoothly.
  12. Roland Deschain
    Lastly got the wheels mounted today. Pro Comp 69 series, 4wd has a promo going on buy 3 get one free.
  13. Roland Deschain
    Got the steering dampener installed today had hoped to get the tune up done today but just didn’t work out.
  14. Roland Deschain
    Well I ended up doing the tune up after all. Everything except the fuel filter. Air filter was packed and spark plugs were absolutely shot.
    A5A976C8-9DE0-47A4-9DB8-65D8569A9D5E.jpeg 1C9D8014-8839-4105-B259-EE7283993135.jpeg
    Perkolator and Erwin Merida like this.
  15. Roland Deschain
    3848D78A-8BF0-462B-9E93-E913F7CA6047.jpeg Got the fuel filter changed, would defintely consider a relocation kit. I'm sure some folks find it a piece of cake but I struggled with it. I'd changed plenty of 22R fuel filters but this was the first 22RE and I couldn't believe the location. There was a Toyota fuel filter on it, no idea how long it has been on. Based on the condition of the air filter and spark plug I imagine its been a while.
  16. Erwin Merida
    ..and yet it still ran like a champ! That's why I love these trucks. You can beat on them and they just keep trucking away!!
    Perkolator and Roland Deschain like this.
  17. Erwin Merida
    Have you tried using it in 4wd? Does it engage smoothly?! Most ppl over look that part of maintenance too.. just food for thought
  18. Roland Deschain
    Seems to engage pretty easily it I plan on servicing the drivetrain next.
  19. Roland Deschain
    Off to a friend’s shop for timing chain kit, water pump, belts, hoses, thermostat, valve cover gasket, oil pan gasket, oil and filter obviously and pitman arm install. They centered the steering wheel and may have fixed the speedometer, was working intermittently now all the time. They know Toyota’s inside and out. The tech that did my truck has a 1994 with less than 120,000 miles on it. Seems to be running a little stronger so imagine that the timing chain not being properly tensioned was some of that.
  20. Roland Deschain
    Replaced the factory AM FM Cassette player last night.
