mounting bed
Discussion in 'Exterior/Body' started by BotDoc, Jun 21, 2011.
  1. BotDoc
    BotDoc Newbie
    K so I fixed the frame rot and I am just about ready to mount the bed back on. Originally the lines didn't match from the bed to the cab as the bed was to low. It was mounted on square rubber pads with no shims so my question is are the pads crushed and need to be replaced? If so were can I get them from? If they just get shimmed what do you guys use as shim material.
    Cheers Steve
  2. eurofreak2002
    eurofreak2002 Toyotaholic
    B-town 208
    The rubber pads are so it doesnt sqeak. You could try using more pads but I would use a big round or square washer or shims. If you got a drill then make your own shims out of scrap steel or something.
  3. dillinja666
    dillinja666 Toyotaholic
    I gots no truck, for now
    ya just shim it up and make sure there is rubber somewhere in the combo or else you gonna have a squeeky bed every time you hit a bump.
