modify reverse lights
Discussion in 'Interior/Electronics' started by yota89, Feb 3, 2014.
  1. yota89
    yota89 Enthusiast
    guam
    89 single cab
    Yo guys need some help is it possible to modify reverse
    lights the plugs on the trans but i didnt find a harness on the
    bottom of my cab so im wondering if i can make my own wires
    help thanks
  2. Litneon
    Cocoa, FL
    94 xtra cab
    What exactly are you wanting to do? Of course they can be modified, but to what end?
  3. yota89
    yota89 Enthusiast
    guam
    89 single cab
    Im trying to turn on my reverse lights i have no reverse light
    And i wana try tapping in from the trans to the harness but idk where
    or wat wires to tap into
    So basically i need reverse lights
  4. White Trash
    White Trash Toyotaholic
    Eastern WA
    89 auto cross beater
    Red wire with a black stripe is reverse lights everywhere.
  5. yota89
    yota89 Enthusiast
    guam
    89 single cab
    So where do i find the wires?
  6. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    Could run a toggle switch sending power to the reverse lights on the tails. Then you don't have to be clutched out in reverse. Allows slower park control while lit up.
    Or turn the haZard flashers on, the orange is a nice lit up flow backing up. It's what I do lol. My reverse lights are weak.
  7. raylcc
    raylcc Addict
    Denver, CO
    You could always run a momentary-on switch to a mount on the shifter. When the shifter is put into reverse, it would press the switch in and turn on the back-up lights. If you wanted really bright back-up lights, you could run the same setup to a set of auxiliary lights mounted on the bumper. Use anything from a cheapie set of fog lights all the way up to huge off road KC's. However, due to the incident in my youth, I have to advise that you check local laws before installation.
  8. standardbyker88
    lynnwood, wa
    If you mount extra lights tuck them up under the body so they flood the ground but aren't even seen from the rear when off. It would also help protect them. Any set of $15 auto parts store fog lights would be a huge amount of light to backup. Some are coming out as LED too.
