Misfire help
Discussion in 'Engine/Drivetrain' started by dragoon713, Jan 19, 2016.
Tags:
  1. dragoon713
    dragoon713 Newbie
    San Bernardino, CA
    1974 Hilux long bed
    I have a 74 Hilux with a weber carb, almost brand new, and over the weekend my truck started to misfire. The weather was damp and cold, like 1 A.M. in the morning. It grew a little worse so I changed the plugs and wires. That fixed most of the problem, but it still does it at specfic throttle levels and engine loads. I checked the points and they look good, supposedly when I bought the truck, a year ago, they had been changed.
  2. jetas
    Probablt a fuel issue
  3. dragoon713
    dragoon713 Newbie
    San Bernardino, CA
    1974 Hilux long bed
    Pump or ratios? Most of my experience is with fuel injection not carbs.
  4. jetas
    have you checked if the points are gapped right? They could be good but gap could be off. Just a thought.
    Fuel filter might be crap? Idk just throwing things out
  5. dragoon713
    dragoon713 Newbie
    San Bernardino, CA
    1974 Hilux long bed
    I checked the points and there are gapped correctly. The filter has less than 10k on it. Hopefully, I'm going to change the pump this weekend and retune the carb.
  6. jetas
    Is it a mechanical pump?
    Obviously should be but things get changed lol
  7. dragoon713
    dragoon713 Newbie
    San Bernardino, CA
    1974 Hilux long bed
    It is the mechanical one. I pulled it off after purchasing the truck and nothing seemed wrong with it, but it is definitely aging.
  8. jetas
    You can get one for cheap. Swap that bish out.
  9. dragoon713
    dragoon713 Newbie
    San Bernardino, CA
    1974 Hilux long bed
    The past few days its gotten worse, I did changed the pump and that didn't seem to effect it. Its started to misfire a little even while idling.
  10. dragoon713
    dragoon713 Newbie
    San Bernardino, CA
    1974 Hilux long bed
    I spent a couple hours running through every possible thing on the engine and found that the nut holding the condenser in place had come loose. I tightened it up and runs amazing.
    josephf786 likes this.
  11. jetas
    Damn those grounds
  12. josephf786
    josephf786 Newbie
    Glad everything worked out! i have a '76 "hilux" and it's doing something very similar and it's getting worse by the day = (
    Where is the condenser located, is that under the distributor cap?
  13. jetas
    I dont think the 76 had a condenser. Check the connections at the coil and ignitor
  14. josephf786
    josephf786 Newbie
    i dont think so either. i was like, am i missing something? lol i'll check those, thanks jetas. I definitely have a vaccum leak around that double plate spacer thing on my Weber. not so sure a vacuum leak would cause all that loss of power and sputtering, but maybe it would. I'll reply when i fix it!
