Mini C-notch bracing
Discussion in 'Suspension/Chassis' started by silverblazer50, Sep 2, 2014.
  1. silverblazer50
    silverblazer50 Enthusiast
    Thomasville GA
    1994 reg cab
    I've looked at a couple different peoples mini notch, and was wondering if a brace on top of the frame is needed. I see some people weld a metal strap on top of the frame.
  2. jetas
    I cant see it hurting it. Box the open side too
  3. White Trash
    White Trash Toyotaholic
    Eastern WA
    89 auto cross beater
    If you use a thick enough piece for the bottom I don't see a reason for an upper brace. I used 1/4" plate for mine since I only cut up to the bottom of the rubber plug on the outside of the frame. That notched it just under 2".
  4. silverblazer50
    Thomasville GA
    1994 reg cab
    I've got a 3" plate already built out of 1/4 plate. Looks like the bolt in kits you buy, just weld in. Just looking for advice, doing it shortly.
