Metal Thickness
Discussion in 'Suspension/Chassis' started by pivins45, Mar 26, 2013.
  1. pivins45
    pivins45 Member
    Wilmington, North Carolina
    94 Pickup Ext Cab
    Just curious.... What size thickness 2x4 square tubing should I be using on the Notch? 3/16"?? The guy at my metal shop only has 1/4" thick in stock. I figured that was too thick and cost too much for what I need it for. Any suggestions are open.
  2. yota4life
    yota4life Grand Toyotaholic
    lodi ca
    1991 xcab 2wd 4cyl
    I use 3/16". Id also go with 2x3 should be cheaper and thts all you need
  3. Under Construction '93
    Under Construction '93 Addict
    Riverside,Ca
    1993 Std Pickup
    This ^
  4. pivins45
    pivins45 Member
    94 Pickup Ext Cab
    Aight, thanks fellas..
  5. Xs5875
    Xs5875 Addict
    Greenville, Ga
    1994 Standard cab 22re 5 spd
    Mines 2x4 1/4". And was a mother to cut and weld in.
  6. burnzya
    burnzya Grand Toyotaholic
    arizona city, arizona
    bodied 73 hilux
    i use 2x3 .120 wall tube when it's going on a minitruck.
