Been on google for a while trying to find some straights answers. Will those 5 spoke oem mazda 6 wheels fit on my 93? Found a cheap set on craigslist recently and I just wanna make sure they will perfectly fit. Any help is appreciated. http://www.partsgeek.com/gbproducts...&fp=pp&gbm=a&gclid=COOivoaSxLcCFYiDQgodOToAkA
Not sure actually. Best bet, call the For..I mean Mazda dealership and ask for the service dept. They should know if they are worth a crap. I see a lot of those ugly station wagons here in town, usually the rims are powder coated some obnoxious color and the owner is a 1st class dousher! JUST my 0.02 OT- Is that the Zig Zag man in your Avi?
I found some info on the offset and bolt pattern. It was only a quick search though. Bolt pattern lines up. 5x114.3mm (5x4.5") Offsets are reported to be in the +55 to +60 range. Which means you have a backspacing of something like 5.5" or so. I don't know about the '93 yotas, but last I heard you should be shooting for a backspacing under 4", with 4.5" as near max depending on the specific rim diameter.
18" OEM RX-8 5-spoke 5x114.3 18x8 +50mm offset 17" OEM Mazda 6 5-spoke 5x114.3 17x7 +60mm offset 21.1Lbs 16" OEM Mazda 6 5-spoke 5x114.3 16x7 +55mm offset 21.1Lbs
My experience with wheels is that they never clear the front hubs and I always have to find a machine shop to mill the centers out! Then the center caps usually don't fit because the bearing cap sticks out to far!
