Material of stock spindles?
Discussion in 'Off Topic' started by '80yota, Sep 28, 2011.
  1. '80yota
    '80yota Enthusiast
    Spokane, WA
    '80 Sr5 Long bed
    What is the material of stock front spindles? Weldable?
    Got a 67 stout with 78 spindles and discs swapped on and want to make some drop spindles by modding stock ones. Was going to cut about a 2 inch piece out of the top and cut and add it to the bottom to raise the spindle, effectively making a drop spindle.
    This going to be doable? This metal going to weld or not?
  2. dillinja666
    dillinja666 Toyotaholic
    I gots no truck, for now
    i think its crap cast metal. if you know about welding cast go for it, if you never had i wouldnt do it.
  3. SuperRA
    SuperRA Newbie
    Most likely made from cast iron. Not very weldable and on such a high stress part, I wouldn't trust even the best welders to weld that piece. That's my $0.02.
  4. Litneon
    Cocoa, FL
    94 xtra cab
    Yep, it's Cast Iron. It is weldable, but I would never attempt it on a spindle. Like SuperRA said, it's a high stress part. I know if it cools too quickly, the weld is very likely to crack away from the cast. Very tricky.
  5. '80yota
    '80yota Enthusiast
    Spokane, WA
    '80 Sr5 Long bed
    ok. thanks for the input. Was going to take it to the welding shop at my school and see what the instructor could do but my guess is he will say the same thing...
    Maybe time to make custom tubular spindles..hmm
  6. yota4life
    yota4life Grand Toyotaholic
    lodi ca
    1991 xcab 2wd 4cyl
    Ya just make some custom ones if you have the know how and ability
  7. GrantH
    GrantH Addict
    Hattiesburg, MS
    buy drops or have them built by Max or Seth.
  8. Twisted Minis
    Twisted Minis Addict
    Poor Cal
    1980 Toyota
    Ya from what I understand the 80s drop spindles can work on the older trucks.
    Also they are cast steel, not iron. I have reworked stock spindles before, but its tricky and I would not recommend it. The way you mentioned doing it really is not the correct way. Not even close, I see stress risers in your design that would fail. Also if you look at the spindle design, your idea is not likely possible.
    Also do you know anything about spindle geometry? KPI? Ackerman? These are very important things to know going in.
  9. Litneon
    Cocoa, FL
    94 xtra cab
    Cast steel.... Good call Seth. My bad.
  10. '80yota
    '80yota Enthusiast
    Spokane, WA
    '80 Sr5 Long bed
    Yeah, soon as the cast came into play, I knew I wouldnt be modding stock spindles. Done my share of welding cast (both steel and aluminum) and I dont like it, nor would I trust the entirety of my truck on welding some.
    Im gonna grab a spare set of spindles still, and look into making a set of tubular spindles.
    Unless anyone else has a good idea to get 4 inches or so of drop out of the front of a 67 stout (without bags)
