Major Pain!
Discussion in 'Engine/Drivetrain' started by 88Sandshark, Nov 5, 2009.
  1. 88Sandshark
    88Sandshark Toyotaholic
    Lake Elsinore, CA
    I have gone through 3 brand new clutch master cylinders and I absolutely hate messing around bleeding that system. Yesterday, I swapped out my third for another of a different manufacturer (under warranty at Autoaid).
    Yesterday I spent four and a half hours bleeding it, then my dad tells me at the last minute that his brake bleeder's f***ed up.:rolleyes:
    Weird things I noticed though... the new one seems very responsive with subtle clutch release, and it squeaks every once in a while (any thoughts?)
    I measured the pedal to cylinder edge and it is exactly the same(repeated from OE Toyota to the third), so no problems there.
  2. joeynational
    joeynational Toyotaholic
    PHX,AZ
    91 2WD
    i've had the same issue with brake mc..i'm on my third one,and now its leaking.
  3. 88Sandshark
    Lake Elsinore, CA
    Ouch. That one has to be even worse to replace; mechanically and more so if you don't bleed it all the way...
    In my case, his bleeder kept sucking air that wasn't even in the system, it apparently has a few bad fittings. Even still, I managed to get everything set up for me to do my 25 mile morning commute.
    If I have to do one more, I'm going to cuss up a storm, then make a dictionary of all the words - on top of that, get a new bleeder screw, my 10mm wrench rounded it off a bit...
  4. FOKAI
    FOKAI Veteran
    SD
    84 truck, 05 4Runner
    What brand master cylinder are you buying? I say buy an OEM one from marlincrawler or lc.
  5. 88Sandshark
    Lake Elsinore, CA
    Two were Wagner, I don't know who this new one is, just it was a little bit pricier.
    I'm a starving college student with a 4x4... hard to get a lot of spending money...:rolleyes:
  6. FOKAI
    FOKAI Veteran
    SD
    I hear ya. A new oem master cylinder costs $60. I think that's cheaper than the 3 you have bought.:waytogo:
  7. 88Sandshark
    Lake Elsinore, CA
    New cylinder was "Beckarnly" or some kind of thing like that. Hard to read the logo.
    I didn't have to pay a cent for some of my relacements, but this new one was pricier. I asked my uncle what he'd recommend (as it's his shop) and he said to try this one, only $7 more.
    Other than the occasional squeak, its working great... I'm getting used to the over-responsive pedal feeling (it could have been that my last one was getting too worn out...)
  8. Evolmotorsports
    Evolmotorsports Veteran
    SCV cali
    1987 RN50 Hilux
    Replace your slave cylinder, I had the same problem, the rubber is probly falling apart in the slave contaminating the fluid and tearing up the new seals in the new master, the squeaking can just be a dry pin on the master.
  9. 88Sandshark
    Lake Elsinore, CA
    I'll give that a try. Thanks Evol!:waytogo:
  10. joeynational
    PHX,AZ
    91 2WD
    autozone/checkers
    i bleed them correctly before install but with my last two, i would be driving and my truck would start to slow i give it more gas and it bogs down, then i realized my brakes were locking up. i had to pull over and bleem them ever 3-5 miles to make it home..this one i currently have has been working for 6 years or so but its starting to leak now....sorry dont mean to thread jack
  11. 88Sandshark
    Lake Elsinore, CA
    I prefer to get my parts from my aunt and uncle's shop, not only because they are family and I get a discount, but also because 1)they can get very high quality parts and 2)if it's not in stock, they'll order it - usually ovenight delivery.
    I'm going to be getting my Toyota bumper brackets frome them soon, as well as a chrome bumper.
