Maf problem?.
Discussion in 'Maintenance/Repair' started by CHOPER211, May 11, 2010.
  1. CHOPER211
    CHOPER211 Newbie
    I intended to clean my MAF senson but i didnt do my research before hand i unscrewed the connector and pulled out the whole thing i noticed it was obvious i did sumthing wrong so i cut out the silicon around the top cover to expose the inside i noticed that the two small metal parts that are sodered together broke apart frm each other i made sure they where touching when i reassembled the MAF the truck is running just fine but i would feel better if i could put it bak the way it was.The only thing is that when im drinving it the check engine light comes on for a few seconds then turns back off. So now my question is will my MAF sensor be ok or do i need to replace it now because of the small sodered parts that came apart. Please help i need to take my yota on a trip soon and i have to make sure its in perfect working order.
  2. Frinzo
    Frinzo Toyotaholic
    Hinesville, GA
    '86 Std Cab
    u need to replace it..
  3. jetas
    Just replace it. The JY where i go to they said it wud be like $20 for a replacement..
