Madi's Project
Discussion in '1984-1988 Build-Up/Project Threads' started by ASI H8, Dec 9, 2021.
  1. ASI H8
    ASI H8 Newbie
    Mid West
    69 FJ40, 85 2wd X-Cab (Madi's Project), 88 2wd Reg Cab, 00 4Runner Limited
    The end state of this project is a fun little truck my children can use through high school. After they are done with it, the wife and I will be rolling around the nation in it. I'm not super savvy with posting pictures. I'll get my son to help me with that.
    I intend to pull the engine, trans from the 4Runner and stuff it into the 85 with a SAS.
    What I have to work with:
    1985 2wd x-cab ($350) (147K Miles): Starts, Runs, doesn't drive but that's ok. All the lights, switches, dials, knobs work except for the horn. Again, that's ok.
    2000 4Runner Limited ($500) (247K Miles): Starts, Runs, and Drives. It shifts through the gears fine. T-Case functions great. Rear Locker works great and has the 4.30 R&P. It is rusted beyond repair so it will donate all it can.
    I have sourced a factory mini front axle housing that has the reinforcing truss and control arm. Now I need to fill it. I was thinking of using a front third from a FJ80. My assumed issues is that the LC R&P is 4.10. I have owned a 97 FJ80 in the past but never messed with the R&P. I have had a person tell me "FJ80 LCs were factory 4.30 R&P." If that is the case, GREAT!!!!. If it isn't a 4.30, no worries. Nitro makes a 4.30 R&P for the reverse cut for the third.
    Big thoughts on how right now:
    Front end leaf springs
    T-case from LH to RH in order to accommodate the solid front Toyota axle.
    Axle widths.
    I know I'll have a ton of questions as this grows. For my first question, What the heck am I thinking????? I'll do my best to search first before posting questions.
    If anyone has converted an 85 2wd to 4wd SAS please reach out. Also, if anyone has stuffed a 3.4 with auto into an 85, again, please reach out.
    Thanks
    Erwin Merida likes this.
  2. ASI H8
    ASI H8 Newbie
    Mid West
    Did some reading and found that I can do an IFS hub swap on the front axle and pick up about three inches. If I do an IFS hub swap, I could use the 2000 complete rear under the truck. Yes, I would have to cut off some brackets and wield on perches for leaf springs. I'd also have to adapt the E-Brake.
    Just wondering if anyone has before and after pictures of doing an IFS hub swap with the same wheels and tires?
  3. ASI H8
    ASI H8 Newbie
    Mid West
    On an unrelated project, I'm having a fuel pick up issue in the tank. I'm guessing I could have the same issue with my 1985. I'll attempt to clean up the tank and use lessons learned for this project. If I need to replace the tank in my 85, I have seen two capacities available, 17 and 19 gallons. I'm guessing with the X-tra Cab I should nee the 19 gallon tank, correct?
    I think I found a pickup assembly, 1985 Toyota Truck Tube sub-assembly, fuel tank suction. Efi, cbr, interior - 7720335361 - Genuine Toyota Part TUBE SUB-ASSEMBLY, FUEL TANK SUCTION PN:7720335361
  4. Erwin Merida
    Erwin Merida Addict
    Long Beach, California
    LEXXXI - '93 Toyota Pickup shorty, with 5 on the floor!
    You might be right on the tank capacity. Longer wheelbase would allow for a longer tank between axles. Take the sender unit out of the tank and make sure it's not broken/torn/bent. Also check all lines to/from.
  5. ASI H8
    ASI H8 Newbie
    Mid West
    Today, I was able to run the 85 from fuel in the tank. GREAT NEWS!!
    On the other project, I broke two (in the middle) of the six bolts that hold the tank. I stopped there and started soaking the other four in JB 80. Grrrrrrrrr
    Wednesday is a long work day. Back at it Thursday.
  6. ASI H8
    ASI H8 Newbie
    Mid West
    Back to Madi's Build by reading a ton of other information. Found Pietro's Project Ol Blue 2WD SAS on Pirate, Project Ol' Blue 2WD SAS | Pirate 4x4. It had a ton of great information on it. For some reason the pictures would not load for me. I spent the entire day reading. Wife isn't happy about that. Looks like I'm in the doghouse.
  7. Erwin Merida
    Erwin Merida Addict
