lspv ???
Discussion in 'Suspension/Chassis' started by krazedprof, Apr 12, 2009.
  1. krazedprof
    krazedprof Addict
    iowa
    1991 reg cab & 1994 4runner
    so i have been tryin to read up on this part and i found many things on 4wd on other sites but where the hell am i suppose to mount it on a truck that is bagged and lays frame let me know if any one knows . also here is a pic of what she looks like now.
      File size:
      77.2 KB
      73
  2. burnzya
    burnzya Grand Toyotaholic
    arizona city, arizona
    bodied 73 hilux
    the one on the rear brakes right? take it off and put a regular tee fitting in.
  3. krazedprof
    krazedprof Addict
    iowa
    yeah on the back and it will still work fine
  4. burnzya
    bodied 73 hilux
    yeah it will be fine, but you might need to install a regular proportioning valve to keep the rears from locking up. your probably not going to haul much in a bagged truck so there isn't a need for it.
  5. krazedprof
    krazedprof Addict
    iowa
  6. burnzya
    bodied 73 hilux
    i think that would work.
  7. krazedprof
    krazedprof Addict
    iowa
    ok so ill probably order one of those also i don't know what kind of t to use thanks for all ur help.
  8. lownloud
    lownloud Toyotaholic
    Plains, Montana
    I went getto cheap when I ran outa cash on mine, I just kept the original valve and adjusted it after bolting it to the frame - at the same time, cut of the rod to the axle. Ghetto but it works, if ya have the cash, " Tee and B happy!"
  9. CajunTaco
    CajunTaco Enthusiast
    Louisiana
    92 Reg Cab
    I connected the rubber hose on the back to the pressure line from the master. Then removed the return line that goes to the front brakes and removed that T. Throw the LSPV away and mine stops great!! Before it would lock the front brakes in the rain, now it stops super hard.
  10. ShoNuff
    ShoNuff Toyotaholic
    seattle
    75 hilux, 80 4x4
    you could just get the needed bits off a 72-85 celica.
    prolly no more then $20 at a yard for a T and a new proportioning valve.
